Saved IO Settings Not Recalling Correctly PT 12.5.2 Mac
Hi
Anyone know why my saved Mac/El Capitan IO Settings do not recall correctly? For example the Bus order changes. Though all correct saved Bus configurations are all there. But at first glance it's a little unsettling not seeing the exact IO settings come up as originally saved.
System Details |
Re: Saved IO Settings Not Recalling Correctly PT 12.5.2 Mac
i have aseen some odd things happen in I/O as well .. cheers john
Please note: Yes on correct saved IO settings the busses are not properly sequenced in numbers but not a problem. Pro Tools Correct Saved IO Settins .jpg Pro Tools Import IO Settings Incorrect After Save .jpg
System Details |
I posted pics. Well?
System Details |
sorry, i usually get an email when Quoted and i did not .. if you hit the word Name at the top .. it should reorder the I/O window you are in ... not sure why but i have seen odd things happen in the I/O forever .. i wish i had more for you .. but try the NAME sort .. yes, i agree it should save exactly as you wish ..
PT has been very disappointing lately !!
I've been seeing this for a while now... at least all the way back to V11, probably earlier.
All the correct assignments will be there, just not in the order they should be. Seems somewhat random, too. Unfortunately, given the number of bugs and quirks in PT right now, this is actually pretty far down the list in terms of importance, for me at least.
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
But wait! There's MORE! If you ever open a session that was brought in from any other setup, your IO>Bus tab will likely be bloated with any number of new paths(depending on what the other system had). Its best to delete them as soon as you open those sessions and save(and double-check for duplicate paths, especially the for the main outputs)
I/O Pro Tools 12.5.2is NOT recalling Saved I/O Correctly | shamanrock | Pro Tools 12 | 1 | 10-05-2016 06:58 AM |
Loom not recalling saved parameters correctly | Eric Lambert | AAX Plug-ins | 20 | 12-12-2013 04:51 PM |
EQ3 Not recalling/saving settings | slaterweezer | Pro Tools TDM Systems (Mac) | 0 | 04-09-2012 10:42 AM |
EQIII CS2 Not recalling Q correctly. | allstaar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-19-2005 01:07 AM |
FilterBank settings not recalling? | Eric Lambert | Pro Tools TDM Systems (Mac) | 1 | 06-12-2002 11:05 PM |
