Old 10-05-2016, 01:50 AM
shamanrock shamanrock is offline
Default I/O Pro Tools 12.5.2is NOT recalling Saved I/O Correctly
I open older session I/O Pro Tools 12.5.2 is NOT recalling Imported Saved I/O Correctly.
In spite of Importing my saved I/0 settings across the board.
I open newer session with same I/O setting I need to be recalled in older session and the IO settings work properly.
Please help
Ok I don't know what's going on here with pro tools I/O as stated it should recall all my older I/O settings but I don't have time to waste I re-saved all I/O settings from session that works.
Thanks anyway
Peace
Thanks
System Details
Old 10-05-2016, 07:58 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: I/O Pro Tools 12.5.2is NOT recalling Saved I/O Correctly
Trashed prefs? That might help since that's related to the prefs....
12.5.1 is working as far as I can tell....
Daniel
Pro tools did not shut down correctly! Raoul23 Windows 41 03-08-2016 05:16 PM
saved copy in >> cannot read session - why is it saved as alias file? [SOLVED] kindkind Pro Tools 10 4 01-30-2016 01:42 AM
Loom not recalling saved parameters correctly Eric Lambert AAX Plug-ins 20 12-12-2013 05:51 PM
pro tools 8, can we now see the waveforms correctly??? paulreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-07-2008 02:47 PM
EQIII CS2 Not recalling Q correctly. allstaar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-19-2005 02:07 AM
