Old 12-18-2013, 06:29 AM
evilstudios evilstudios is offline
Banned
Default is there a way to get rid of elastic audio warble sound.
I'm using elastic audio even though i try not to as much as possible. There is a bunch of automatically created markers that create a warble sound I'm sure we all know to well. Iv deleted the markers i don't need but the unremovable markers are leaving a sound that is plain useless. there has to be a way around this , does anybody have any pro tricks for this.
Old 12-18-2013, 06:43 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: is there a way to get rid of elastic audio warble sound.
I find that elastic audio works well with transient rhythmic material in rhythmic mode. On more sustained material I always seem to get some warble artifacts aswell. Sorry. Maby someone have some tips.
Old 12-18-2013, 10:03 AM
mickelini's Avatar
mickelini mickelini is offline
If you haven't already, try all algorithms. Pay no attention to what they're called. Sometimes Polyphonic works better on a rhythm source, etc.
Old 12-18-2013, 11:05 AM
Here's some more possible help. I often will add a blank audio track below the one I want to work on, and copy/paste the region/clip that needs work, to the blank track. By grabbing a section of audio, when you copy/paste, you create a new piece of audio, so you can screw it up without losing the original(and yes, EA can screw things up). Another option is to duplicate the playlist, then consolidate the dupe to create a new audio file.
Regarding using EA, small moves usually yield "nicer" results(but this is no guaranty). For vocals and bass guitar, the Monophonic setting USUALLY works best(but I agree that others are worth a try). Sometimes, I will fix the audio I copied to the separate track, and, instead of committing it, I will simply route and record back to the original track(sometimes things sound good until you commit the changes). Sometimes, after failing to avoid the "warbles", I may choose to simply move audio around by slicing it up(this works better on some sounds than others and I use this technique for drums and bass).
If you wish to use Elastic Pitch, then you MUST use the Polyphonic setting.
Old 12-18-2013, 01:37 PM
Banned
Thank you very much guys , I will have to try those , my approach did not have the results I wanted so maybe a hybrid approach to as you all suggested might work best. Couldn't possibly sound any worse than the warble soup i mucked up.
THANK YOU
Old 12-18-2013, 08:07 PM
elicious elicious is offline
so, you're talkin bout analysis markers, correct?
if you haven't already done so,
you can go to elastic properties,
and set the sensitivity to zero
and often that helps.
also x-form usually will clear that up...
e
ihatetyping
Old 12-19-2013, 02:03 AM
gibsy gibsy is offline
Hi Everyone While you guys are talking about elastic tracks. I have an issue trying to comitt to the desired speed of an avid drum loop. After i select "None Comitt" in the elastic part of the track i get this message that i have attached. ANY IDEARS GUYS? I need help (not just with my spelling)
Old 12-19-2013, 02:27 AM
cwsand's Avatar
cwsand cwsand is offline
You should start a new thread with all of the info you can provide.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Old 12-19-2013, 02:30 AM
cwsand's Avatar
The "secret" I was told a few years ago when EA first came out was to select whichever algorithm suits the track for editing, then choose XFORM to "finalize" it before committing. Is this still the proper or normal protocol for using EA? I always used to get better results when doing it this way.
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2019.6
Old 12-19-2013, 11:59 AM
mesaone mesaone is offline
Technically, it should make no difference in quality than picking XFORM from the beginning. If the goal is to save time, then yeah it should work - put the tracks in realtime processing when you're editing, and when you're done switch to XFORM to print (commit) the material.
Here's the thing: XFORM is rendered only. So when you switch, it will have to render all the clips you performed warping on. Here's another thing: Tracks with multiple playlists don't like to be switched from realtime to rendered. The main playlist will render, but all the other playlists will display offline waveforms.
Luckily, I have discovered a workaround. Select each "offline" clip with the object grabber. Copy and paste in place (or promote to main playlist and then undo). This will prompt the elastic audio to render offline with whatever algorithm your track uses.
Pro Tools 10.1.2 Elastic Audio Warble rogercollege Pro Tools 10 8 12-02-2012 06:41 PM
Elastic Audio Issue (damaging sound) -GS- 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 08-28-2012 12:27 PM
Render elastic audio alert when not using elastic audio! weird! jjboogie macOS 7 03-26-2012 10:01 PM
Elastic AUDIO, or Elastic TIME? SoundWrangler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-14-2007 12:21 AM
High Frequeccy Warble Sound? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-03-2001 09:03 PM
