DVD-R burning with Apple Superdrive
Anyone having success burning data DVD-R backups with an Apple Superdrive? Apple claims that their DVD-R spec only accomodates video DVD-R's burned from iMovie, but Roxio says that Toast 5.0.2 should work.
I've gotten two to burn successfully, but most of the time, Toast hangs when a blank Apple DVD-R is inserted. G4/733 digital audio, OS 9.1, Toast Titanium 5.0.2, Mac OS base extension set |
Re: DVD-R burning with Apple Superdrive
I don't know if this would help, but with your machine, you might try moving up to OS 9.2.2. Perhaps there's been a fix. (It couldn't hurt.)
Lee Blaske |
using 9.2.2 on a G4 867 Toast 5.0.2. Works flawless never a problem.
Cool, I'll try 9.2.2. Are you using Toast 5.0 or 5.0.2? Are you backing up Pro Tools sessions (not that it should matter what the data is)?
tdm guy, perhaps using mac base extension set is the problem.....may be some extensions that you need, that arent in that set???
Also using 9.2.2 on a G4 867 -Toast Titanium... works great.
tdmguy-
turn off all extentions that have to do with iTunes, Authoring Support iTunes Extention i think that will fix your problem. i had the same probelm until i turned them off. i have been backing up Protools to DVDR ever since. good luck -americancheese- running Toast 5.02 Mac867 w/Superdrive
HD3 PT8.x 3 192 24in 48out MacPro quad core 3.2GHz 8gig Ram osX 10.5.5 Euphonix cs2000 |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by AmericanCheese:
tdmguy- turn off all extentions that have to do with iTunes, Authoring Support iTunes Extention i think that will fix your problem. i had the same probelm until i turned them off. i have been backing up Protools to DVDR ever since. good luck -americancheese- running Toast 5.02 Mac867 w/Superdrive<HR></BLOCKQUOTE> Hey hey hey... stop a little here... Are you absolutely sure about this??? I mean, APPLE CD/DVD DRIVER is a part of the Authoring support package!... Will my Superdrive work perfectly WITHOUT that extension?... DigiDAW. |
when i was having the same problem, i called raxio and they told me that the itunes extentions mess wtih toast, and to turn them off. ever since then i haven't had any problems.
i belive that the Authoring Support extentions is used only if you want to burn a cd with itunes. my dvdr works fine without it.
using Apple Superdrive for audio | where02190 | General Discussion | 9 | 02-15-2003 11:43 AM |
Burning DVD with superdrive? | hzway | General Discussion | 8 | 11-29-2002 03:18 PM |
Does Jam 2.6 support the Apple Superdrive? | AlanB | Pro Tools TDM Systems (Mac) | 10 | 04-24-2002 03:13 PM |
burning cd - mac superdrive? | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-05-2002 06:43 AM |
Problem burning audio on 733 G4 SuperDrive | wisperthal | Pro Tools TDM Systems (Mac) | 4 | 06-03-2001 05:26 PM |
