HD 192 Expansion card Analog inputs 9-16
I just bought the hd 192 expansion chasis to give me full access to using the 16 preamps of the Control 24 board simultaneously. I was having some trouble setting up my I/O however.
When I create a track and go to the input, it lists analog 1-8, optical 1-8, and spdif l and r. What changes do I need to make in order to see analog 9-16 to appear as well? |
Re: HD 192 Expansion card Analog inputs 9-16
You need to add additional input paths in I/O Setup.
-Eric |
FYI, after having installed the expansion board, I went to my I/O setup and didn't see Ananlog 9-16 in the tabs. I opened up the chassis again and double checked the ribbon connector. Sure enough, what I thought had been a good connection was, indeed, not. I would double check that.
Inxys,
In hardware setup, make sure you have inputs 9-16 set to the analog inputs. In I/O Setups go to the inputs tab and either hit default in the lower right hand corner or or like ekuehnl suggested, add the input paths manually. regards, mike |
Thanks for the help, I'll try those suggestions. Hopefully that will work.
Digidesign Avid 192 Analog D/A output expansion card for Pro Tools HD | Ghost In The Attic | Buy & Sell | 1 | 04-13-2014 04:35 PM |
Digidesign 192 Analog Input Card and Analog output Card for Sale | MusicEngineer | Buy & Sell | 1 | 03-03-2014 09:03 AM |
192 I/O How to Install Analog Output Expansion Card | Aten | Pro Tools TDM Systems (Win) | 3 | 07-21-2013 05:49 AM |
Digidesign 192 analog out expansion card | steviemac74 | Buy & Sell | 1 | 07-28-2012 12:35 AM |
HELPPPP. 888 card analog inputs noise | peppercat | Pro Tools TDM Systems (Mac) | 3 | 08-26-2001 08:29 AM |
