Old 01-23-2007, 01:01 PM
TXDigi TXDigi is offline
Default Mackie HDR24 to ProTools Convert
anyone know how to do this?
Mackie made at one point a program called HDR Pro but it isnt made anymore, or atleast commercially available
thanks
HF
Old 01-25-2007, 08:24 PM
mixx mixx is offline
Default Re: Mackie HDR24 to ProTools Convert
thanks
just render/consolodate/merge [forget nackie nomenclature but i cut drums at a studio that has that recorder and it's just like consolodating on PT] each tracks regions at the same start point
Old 01-26-2007, 01:50 AM
PeterB PeterB is offline
I've done this by using the Mackie external hard drive unit with fire wire, [I forget what it is called]
The Mackie records timestamped bWAVs, so once you have duplicated your session on to the external Mackie drive unit, unmount the drive from the Mackie and connect it to you MAC and copy the files over. Import them into protools using spot to original time stamp.
Make sure you name the tracks in the mackie first, so you don't get a bunch of files called "audio 1 audio 2" etc etc
PB
TechnologyWorks Mastering
http://www.technologyworks.co.uk
Old 01-26-2007, 11:28 AM
PB
so did i but i rendered the track in the mackie picking a grouped time start after the tracks were done..i 'll will try yoour way next time but when i tried this before PT saw no time stamp from mackie wav's
convert Mac protools 7.0 to windows protools 6.4? Strainj1 Pro Tools TDM Systems (Win) 1 11-07-2006 10:42 AM
ProTools Convert gjohung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 12-26-2005 07:39 AM
Transfer Files from PT to Mackie HDR24/96 tfrench4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-12-2005 09:13 AM
Anybody using Tascam MX2424, or Mackie HDR24/96 with Digi001? pindebraende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-11-2002 12:06 AM
Anyone have success syncing PTLE digi001, D8b, HDR24/96, MTP AV? kid-surf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-10-2002 02:53 PM
