123 minute max record length
Hi, am I missing something here....?
I need to record a 3 hour show to 24 tracks. I am doing test records. I have tried to do it twice and it stops at 123 minutes both times. My max record length was set to 210 minutes the first time. I thought something was weird so for second time I increased it to 300 minutes, still stopped at 123 minutes in free record. At 123 minutes it came up with the box that it ran out of space or disk allocation option ran out...I'm on a fresh 500 gig maxtor SATA drive. When recording the disk meter is at about 10-15% of max usage MAX Should I just allow it to not have a maximum record time? I always have used one in the past because of performance issues. The system does not appear to be stressed or even remotely CLOSE to stressed at any given time. Session is 96k Any ideas? Thanks, Doug system: G5 10.4.7 32 bit 13slot digi expansion chassis HD5 PT 7.2 SATA internal 2nd drive maxtor 500 2.5 gig ram
Doug |
Re: 123 minute max record length
With the session running @ 96k I think you've reached the file size limit (2048MB).
yes, it would be hitting that size around then.
any way around that?
Doug |
BTW:
Why is BWAV filesize limited to 2GB in PT. The BWAV specs allow 4GB. Thanks, Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Well with a fat 32 drive the maximum file size is 2048meg. I think that is why digi keeps it to that. I wish they would do like AVID and allow longer recording it just breaks up the files. This would be good for those times you need to run a longer record time.
Mike |
So Digi, I am assuming this is the final reality for the time being?
Doug |
frank.
Just for my own education, why is that the max file size? Is it a OS issue, a ProTools issue, or what? I have probably had this explained to me before, but if I take in too much info in one ear, some knowledge falls out the other side.
Roy |
Help with M-Powered record length | nitemareseraph | Windows | 2 | 01-30-2014 04:52 PM |
Protools 10.3.3 has a 24 minute session length? | broken81 | Pro Tools 10 | 5 | 04-21-2013 07:28 AM |
Copied region length auto-adjust to paste location length? | greglawrence | Tips & Tricks | 4 | 10-23-2011 12:46 PM |
One minute I have space, the next minute I don't | newtonab | Pro Tools M-Powered (Win) | 3 | 01-03-2009 05:38 PM |
record length maximum | john burton | Pro Tools TDM Systems (Mac) | 2 | 06-29-2001 12:12 AM |
