Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 04-10-2016, 07:21 PM
budubum92 budubum92 is offline
Default Fast track ultra 8r standalone
Im very new here just recently registered as a memeber.
Id like to know if the m-audio fast track ultra 8r could be set in standalone mode.
i cant seem to find any details about it on the users manual and been searching all over google but couldnt get an answer.
the next question would be:
Since i have 2 FTU8R and want to connect these two together to get 16 in/out, is it possible to do so connecting both to SPDIF in out?
i believe i need to make one FTU8R to work in standalone mode and be able to route the standaloned moded units`s Ins directly to its outs.
like input 1 to output 1. and in 2 to out 2 etc...
thanks in advance.
Old 04-11-2016, 07:11 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Fast track ultra 8r standalone
I don't believe the 8r works in standalone mode, no. Also, the SPDIF is 2 channel only, what you're looking for is an ADAT in/out which the 8r does not have.
"MIDI and S/PDIF Connector (MIDI S/PDIF) – The accompanying breakout cable connecting to this multi-pin jack provides MIDI input and output on 5-pin DIN connectors, and S/PDIF input and output on coaxial RCA connectors.
• When the Sync Source drop-down menu is set to “External” in the Control Panel, input channels 7 and 8 will receive their signal from the S/PDIF input instead of analog inputs 7/8.
• The S/PDIF output signal is identical to the output of Line Outputs 7/8.
• The S/PDIF output will also support pass-through of AC-3 or DTS encoded surround formats."
If you wan't to get 16 channels, you'll have to find another device that either has 16 pre's or an 8 pre with ADAT in.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-11-2016, 11:15 AM
Thanks joel for clarifying my question.
I also have an maudio fw 1814 which only has 2 preamp ins and the rest is just ts inputs 3-8.
My second question is, is it possible to route the ins 1-8 of the ftu8r to the outs 1-8 so that i can connect the outs from the ftu8r to the firewire 1814s input 3-8?
That way i dont have to get another preamp to connect to the firewire 1814.
Desktop with W7 and W10 system OS.
CPU:3770K, 8GB RAM, Corsair Force GT 120GB SSD, Asus GTX 560.
Cubase 5 and 7
Loptop: Macbook Pro 15 inch Late 2011 with Yosemite 10.10.5, CPU I7 2760QM, 16GB RAM, 256 SSD, Intel HD 3000/AMD radeon HD 6770M.
Cubase 7 and Logic Pro X
Focusrite Scarlett 18i20, M-audio Fast track ultra 8R, M-audio Firewire 1814.
Roland SRV 2000
Fast track ultra r8 - win 7 32 bit Claxton FireWire & USB Audio Interfaces (Mac) 2 02-03-2014 06:43 PM
Fast Track Ultra - Big thanks and a wish... C.O.D. FireWire & USB Audio Interfaces (Win) 3 08-29-2013 05:35 PM
11R with fast track ultra 8R drew_glue Eleven Rack 6 05-30-2013 07:00 AM
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? epu Pro Tools 10 3 06-13-2012 03:55 PM
track confusion in fast track ultra interface deck Pro Tools M-Powered (Win) 0 02-24-2010 10:17 AM
