PT6.9 MEMORY LEAK!!!!!! COME ON DIGI :(
I know this has been discussed, but come on. it's been a know issue for a couple of months now. Last I heard from Digi, almost a couple of months now, they said they were on it!?!? Guess not.
Re: PT6.9 MEMORY LEAK!!!!!! COME ON DIGI :(
I have never had a problem with 6.9 It runs all day long with no trouble.
5198 Studios |
ye nor me, whats the problem?
The problem is that every time i press play on my system, my memory usage goes up by about 2mb and stays. Then if i stop and press play again, 2 more mb's, and on and on. The same thing if I'm editing. Drums especially. After a short While, my computer will choke cause i'm out of ram!!!
I currently have 1 gb installed. That should be more than enuff to edit drums. But no. 6.4 was fine with my 001. But when I upgraded to the 002, it came with 6.7 (I upgraded to 6.9), and that's where the problems started. I love the new fetures and all, but this issue is pretty big. Open up your "Task Manager" to see if the memory keeps stacking up as you work. For many people and myself, this is a problem. They also said a couple of months ago that they would address this issue within weeks not months.....yeah right. Digi, I love ya, but... |
Please call Digi CS when you get a chance. They will resolve your issue. Digi ETS |
Can Digi CS post a fix here Digi ETS if there is one for this problem?
thanks
soon to be back at it again... |
I also have run across this problem, only on certain sessions, and would be interested to know if there is a workaround/fix.
I'm sure your Mom always told you to share, right???
de_mix
"DE MIX" ? you know I feel betrayed a bit on this one. My business has the name "LE MIX" registered since the mid-eighties. All in good fun mate, don't sweat it ..Happy mixing ! Good luck with that tech issue. God knows.. I am waiting to install 6.9 also after having a rock solid 6.4 system for a year. cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Memory Leak in Protools 10...? | shameusf | Pro Tools 10 | 26 | 09-16-2013 04:34 PM |
Memory leak going 11.01>10.3.6 | DetroitT | Pro Tools 11 | 0 | 07-18-2013 03:42 AM |
Memory leak in EuControl 2.5.7 | DhyanMikael | Artist Series | 0 | 04-23-2011 06:13 AM |
Memory Leak in 7.3? | BlindDog | Pro Tools M-Powered (Win) | 2 | 01-15-2007 08:21 PM |
Memory leak in PT7cs3? | UnkleMik | Pro Tools TDM Systems (Win) | 1 | 02-03-2006 12:53 AM |
