Outboard Converter to ADAT Optical or SPDIF?
Does anyone know if I hook an outboard converter like the Waves L2 Ultramaximizer 24bit/96k to the SPDIF connection on the back of the Digi001 Interface box if I can bypass the internal Digi converters, or do I have to use the ADAT optical to do this? Can I use the L2 as master through SPDIF? Lastly for the digi techs, any word on 24/96 or 192k software support for PTLE? Anyone? Dave? Brent? Eric?
Thanks everone. Allen [img]images/icons/smile.gif[/img] |
Re: Outboard Converter to ADAT Optical or SPDIF?
Ususlly, if you feed a device a digital signal, it only needs to be clocked to the same res and sample rate, but it shouldn't go thru the A/D stage anymore, being already digital; so if you're doing this to use selcted brand converters there shouldn't be any troubles; an A/B test should set this straight. Just set digi as slave (or sync external) via SP/dif. We used to do a similar thing (when I was working as an assistant)with RME converters to go digitally in a DA 98 HR at 24 Bits via Tdif: converting thru RME A/D gave better results than using Tascam's stock converters.
Hope this helps. L.G. [img]images/icons/smile.gif[/img] |
Thanks LG,
I sent you an email. That should do it and I appreciate the help. Allen [img]images/icons/smile.gif[/img] |
using a outboard converter via spdif | stevedresser83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-29-2008 08:07 AM |
spdif to optical converter and using opt and spdif | Hollow Body | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-09-2006 05:41 PM |
whats the difference between adat optical and spdif optical? | Vegadark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-07-2002 07:42 PM |
Adat optical to S/PDIF converter? | MAri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-16-2000 08:34 PM |
Is there a converter for optical to SPDIF? | LaJaZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-11-2000 04:44 PM |
