Old 07-01-2003, 07:42 AM
airwavejoel airwavejoel is offline
Default Can you Print The ProTools Screen?
A simular question was asked months ago pertaining to printing the ProTools screen using a Mac. Many excellent replys-thanks
But, what are the key-strokes that enable you to print the ProTools screen for Windows (especially XP version).
Old 07-02-2003, 12:42 AM
cakes cakes is offline
Default Re: Can you Print The ProTools Screen?
Joel,
Press the Print Screen key on your keyboard, and your screen will be copied to the clipboard. You can then do whatever you want with it. The easiest is to open up Paint (the Windows accessory) and hit Ctrl+V (paste). Then you can save your screenshot in whatever format you want.
Another tip - Alt+Print Screen will only capture the active window, even if it only takes up part of the screen.
cakes
Old 07-07-2003, 08:40 PM
engineerjoel engineerjoel is offline
Hey Cakes,
Thanks for the help. Seems So simple-(duh} I should have known.
But, after I press the Print Screen Key, where under "My Computer" do I go to retrieve the file?
I need to be able to e-mail that file as an attachment.
Thanks again.
Old 07-07-2003, 09:57 PM
Donny Donny is offline
The "Print Screen" button doesn't create a file like the command-shift-3 command in Mac OS. It only copies the information to the clipboard, which is a temporary storage area in RAM. Like cakes suggests, you have to open a program like Paint or Word and press control-c to copy the contents of the clipboard into a document and then you can save the doc wherever you like.
Old 07-07-2003, 09:59 PM
Whoops, I meant to say control-v to paste the contents of the clipboard into a doc. (like cakes also said). [img]images/icons/tongue.gif[/img]
Old 07-09-2003, 08:18 PM
Cakes and Donny,
Thanks for your time and help.
joel
Pro Tools 11 Screen Freeze? wdjudd Pro Tools 11 13 01-06-2016 11:46 AM
Print screen function banjo71 Pro Tools M-Powered (Win) 1 03-24-2012 05:30 PM
Protools 9 registration screen JazzT Pro Tools 9 1 01-20-2011 11:34 PM
Can You Print the Pro Tools Screen? dBHEAD Tips & Tricks 8 01-23-2003 03:07 PM
Protools on two screen Big Fab Digidesign Hardware & Software 2 03-26-2001 04:35 AM
