Old 01-19-2014, 12:43 PM
spiritfallrecording spiritfallrecording is offline
Default Delay Compensation in 10.3.8 seems to be broken
I finally got around to doing the 10.3.8 and 11 co-install because the majority of the plugins i use have been ported. I was on 10.3.4. Anyway, I noticed phase issues when doing some parrallel compression of on a vocal track which means the delay compensation isn't working right. I'm using waves rcomp, req2, and air dist. Delay comp is set to long so it must be broken right? is this a waves problem or a pt problem? I still have yet to install the rest of my plugins so I haven't tested to see if its manufacturer dependent. Anyway, I'm just looking to see if anyone else has been having issues. I'm on Win7 64 bit professional. All tweaks and optimizations have been done.
Jeff Edwards
spiritfallrecording@yahoo.com
Old 01-19-2014, 12:49 PM
Default Re: Delay Compensation in 10.3.8 seems to be broken
so far seems like a waves issue, using all digi plugs i get no phase issues
Jeff Edwards
Old 01-19-2014, 01:12 PM
paul_g paul_g is offline
I'm running Waves 8.0 and PT 10.3.8 and have no issues with Delay comp.
I have tried to duplicate the issue and could not.
I have one track with rcomp, req6 and renaissanceAX, and a duplicate track without any plugs... and there is no issues.
Mid-2007 2.4 ghz Intel Core 2 Duo iMac
OS: 10.7.5 (Snow Leopard)
4gb (667 MHz DDR2 SDRAM)
LaCie Audio Drive - FW800
DigiDesign 003 Factory PT10.3.10
PreSonus DigiMax FS
Dynaudio Monitors and KRK Sub
Line6 HX Stomp
Old 01-19-2014, 01:59 PM
Waves is past version 9 and you should update. Can't say for sure that this is the issue, but until everything else is up to date, how can you be sure the blame lies with PT?
Old 01-19-2014, 04:16 PM
I'm on Waves 9r15
Jeff Edwards
Old 01-19-2014, 04:42 PM
Chief Technician's Avatar
Question Re: Delay Compensation in 10.3.8 seems to be broken
Are you using TDM hardware? If not, what happens when you change the delay comp value to maximum?
Old 01-19-2014, 08:24 PM
Sorry, I got confused by the mention of Waves 8
Delay compensation of I/O plug on parallel Auxes broken? bleen Pro Tools HDX & HD Native Systems (Mac) 12 11-20-2013 07:15 PM
Hardware Delay Compensation broken roberts Pro Tools HDX & HD Native Systems (Mac) 15 01-26-2013 10:44 PM
Delay Compensation broken ArKay99 Pro Tools 10 8 06-22-2012 02:12 PM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 12:10 PM
Delay compensation broken jturner Pro Tools TDM Systems (Mac) 33 09-16-2009 04:55 PM
