Old 07-15-2013, 10:41 PM
mushoo mushoo is offline
Default Command 8/Plugin Learning and EuCon
So, I've got an old Command 8, and I love using it for it's Plug-in Learn functionality... But I just picked up an Artist Mix, and it seems that with the Artist Mix connected/EuCon enabled, I completely lose the Command 8 Plugin Learn ability! The plugin 'Map' interface still appears at the top of the plugin window, but hitting 'learn' never actually lets me map my faders/rotaries to any controls. Any of my old maps are also greyed out as being unusable.
Why isn't there an option to allow the end user to choose which surface they want to map plugins to? Why do you assume that I want to use my Artist series controller? I tried a while back hooking up a command 8 to a machine that also had an ICON connected to it (for weird reasons), and the ICON always takes over the plugin mapping. Sometimes I don't want to use the icon for plugins! Let me choose which control surface to map to - or even better, let me map to ALL of them, simultaneously but separately.
Old 07-28-2013, 11:39 AM
dford dford is offline
Default Re: Command 8/Plugin Learning and EuCon
It's not officially supported to run multiple protocol controllers which is why the choice isn't there. Ethernet controllers will always be the primary controller over MIDI/USB which is why your plan doesn't work.
Dev
one eucon command allowed in macro.. normal? jesse p Artist Series 4 02-03-2016 08:55 AM
will EUCON for S6 have "plugin focus" feature? jacko Avid S6 26 01-11-2015 11:51 PM
PT 11 plugin copy key command gone?/ Sunking Pro Tools 11 4 03-11-2014 12:43 AM
EuCon command for old Command8 "Plug In" window button? myhrik Pro Tools TDM Systems (Mac) 6 06-21-2013 04:48 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 01:01 PM
