Old 01-28-2010, 10:34 PM
cronos cronos is offline
Default Hardware Insert Delay value for 888/24???
hi there,
i'm running PT HD 7.4 with big ben, 96i/0 and an 888/24.
using hardware inserts with much success on the 96, but just noticed that an identical parallel compression insert using the 888 creates phase issues whereas the 96 doesn't.
why would this be happening and how do i stop it before i kill myself? is there a delay value i should be putting into the H/W insert delay fields for the 888?
thanks for any help.
chris
Old 01-29-2010, 01:22 PM
Default Re: Hardware Insert Delay value for 888/24???
can anyone help a fledgling outboard-parallel-processor out?
Old 01-29-2010, 02:23 PM
masterduk masterduk is offline
you will not be able to "mix and match" interfaces, so, if the uncompressed track is using one type of interface, and the compressed track uses another, then it will not be aligned.
it is doubtful that pro tools' "compensate for input / output delay after record pass" function would be accurate for the older interface at all. and its definitely not going to be able to accomodate both types of interfaces at once. its probably seeing the 96i/o and adjusting everything based on that.
since the option to input delay values in the hardware inserts field is not sample accurate, i do not think you will be able to utilize that to make the 888-24 accurately match the 96 i/o either.
not sure exactly how you are routing stuff, so .......
Old 01-29-2010, 07:50 PM
hey, thanks for that response. much appreciated. bummer that that is the case. guess i gotta upgrade? sigh.
Hardware Insert Adds Delay dave911 Windows 7 05-23-2013 05:36 PM
need help determine hardware insert delay musicmixer04 Pro Tools 10 1 02-18-2012 11:22 AM
Hardware Insert Delay Comp Issue therecordinghouse Pro Tools 9 7 11-17-2010 07:01 AM
Hardware insert delay question - Aurora freedomof81 Pro Tools TDM Systems (Mac) 4 01-27-2010 12:10 AM
Hardware insert delay question musicmixer04 Pro Tools TDM Systems (Mac) 1 01-31-2009 08:33 AM
