Old 10-08-2019, 02:51 PM
Jeff ONeil Jeff ONeil is offline
Default Time Compression Plugin not working normally
I updated my system after the OS debacle. I'm now on 2019.5 and High Sierra.
As a VO guy one of my go to tools is the Time compression plugin. Now the "compare" button is not working. I've selected Avid TCE in the preferences, from memory thats what I always had it set to.
I looked in the help menu and couldn't find anything that dealt with this.
Any assistance will be greatly appreciated.
Jeff
Old 10-09-2019, 09:32 AM
Default Re: Time Compression Plugin not working normally
Figured this one out. After cleaning the prefs with no results I decided to look at what was "new" found the T-Rack stuff and uninstalled them all. Solved the issue with the Time Compression plugin.
This "upgrading" can really be a pain!
Old 10-09-2019, 09:45 AM
JFreak's Avatar
JFreak JFreak is offline
Yes it can. Sadly, you can expect trouble with every single 3rd party plug you install. Even if it was current version. Avid only tests Avid plugins.
Janne
plugin selection shortcut still not working properly 100% of the time!!! thebeatless Pro Tools 12 2 07-07-2015 04:43 PM
time compression tool not working properly john1192 Post - Surround - Video 2 07-06-2006 12:32 PM
Time Compression Expansion plugin SkiMan Pro Tools TDM Systems (Mac) 18 03-15-2006 02:49 AM
Time Compression: Shift+Spacebar vs. Plugin MinhSomeLoseSome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-13-2003 11:20 AM
Time compression coaster Pro Tools TDM Systems (Mac) 4 10-22-1999 06:45 PM
