Old 10-17-2019, 03:42 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Miking up a Banjo
Listen to it in the room first and see how it sounds - if you don't like the sound, see what you or the player can do to improve it. Use 2 or 3 mics in different locations and see what sounds best - move them around if you need to. Record all of them so you have options later. It also could make a difference in how you mike it as to what kind of song you're recording.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-18-2019, 04:34 AM
xrekcor's Avatar
xrekcor xrekcor is offline
Thanks for your input... will be placing a couple of room mics.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 10-18-2019, 10:40 AM
Always nice to try multiple mics if you have limited time and only one take, but I think the question was what would be the best educated guess how to record with one mic
Old 10-18-2019, 04:12 PM
xrekcor's Avatar
My first initial thought was a small diaphragm condenser about 11” from the face of the banjo just below where the neck joins the body.
Also thinking of adding an sm57 to the small condenser under and over shotgun style with the sm57 on the finger board. Plus 2 room mics I have a pair of TLM103’s to use.
Rob
Old 10-18-2019, 04:23 PM
Originally Posted by xrekcor View Post
about 11”
Pardon me my french, does that mean "little less than a foot"... bcs in here we have metric system, inches and feet are so strange
Old 10-18-2019, 05:14 PM
27.5 centimeters = 11 inches. Think about it this way - Celestion V30's have that name because they're 30cm across aka 12 inches in the rest of the civilized world
Ever hear of a Marshall cab referred to as a 4x30? Neither have I - they're called 4x12's. Rolls off the tongue easier.
Old 10-19-2019, 05:02 AM
14 posts and not a single banjo joke.............I am impressed I also use an SDC pointed at the neck/body joint(well treated room)
Old 10-20-2019, 02:52 AM
Will Russell's Avatar
Will Russell Will Russell is offline
I have recorded banjo for decades. Is this old time clawhammer or bluegrass style with a closed back? They produce different sounds and play a different role in their respective genres. In either case a small diaphragm condenser pointed toward the head below the right hand is a good start and will produce a nice result. I have also loved using a U87 in the same position. And on a couple occasions an SM57 was the best. Audition the mics in the context of the music.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 10-20-2019, 01:47 PM
xrekcor's Avatar
Ended up using 1 x SE4 and 1 x sm57 both pointed towards neck/body joint.... sm57 on top with SE4 just below. Came out pretty good didnt bother with a room mic. One thing that did show up. When the players fingers hit the strings it created a tap sound which I initially thought was his fingers hitting the banjo skin.... never noticed this before, is slightly annoying but seems to disappear somewhat in the mix. And for the record about 10” :)
Style was closed back claw hammer in a pop song.
Banjo joke.....
This bloke was heading off to a banjo gig, he stopped off to get some beers and accidentally left the rear window down in his car..... frantically remembering his mistake he ran back to his car to find three more banjos in the back seat.
Rob
Old 10-20-2019, 09:20 PM
cwsand's Avatar
Well I live in Georgia now so...
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Any banjo players out there? octoruss Eleven Rack 0 06-19-2011 04:14 PM
Recording Banjo? skycraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-29-2004 08:45 PM
mic'ing a banjo? silence_of_stone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2003 01:33 PM
I have NEVER recorded a banjo...any advice?? Nine Spine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-16-2002 05:24 PM
Recording Fiddle and Banjo? TimOz General Discussion 3 09-19-2001 04:36 PM
