Old 02-07-2013, 07:23 PM
dgoodi22 dgoodi22 is offline
Default Clear selected clips shortcut not working hd 10.3.2
os x 10.7.4 , just upgraded to hd 10.3.2 and now the shortcut has changed from command + shift + b to control and previous commands.
In clips region list and shortcut manual it still lists previous as the short cut . Had to figure this out on my own. Freaking annoying you guys don't pay attention to this.
Old 02-08-2013, 07:58 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: BUG: Clear selected clips shortcut not working hd 10.3.2
NOPE still command+shift+B here 10.3.3
And just to be clear! a BUG is something that affects everyone and is confirmed by other users!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-08-2013, 08:40 AM
joachim's Avatar
joachim joachim is offline
maybe the clip to be deleted was an auto-created one
and in the clip list was not selected "show auto-created",
then Cmd+Shift+B does not work
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 02-08-2013, 12:44 PM
no, I work 10 hours a day with pro tools for almost a decade now and it's not something insignificant like that. Thanks for suggesting ideas, but not sure what is going on. It only works when I use "control" also. Going to update to 10.3.3 and see what happens.
Old 02-08-2013, 01:32 PM
just updated to 10.3.3 and the same problem! have to use : control + Command + shift + B. it worked fine on until I updated to 10.3.2 and .3 .... was working normal on 10.3 ... I have dumped preferences, setup , everything, and still does it. any suggestions would be appreciated. My clips list has everything showing. if i have clips on multiple tracks and select all them in the edit window, the normal command does not work. have to add " control" ..
Old 02-08-2013, 03:17 PM
C C is offline
Haven't seen this behavior but maybe something got changed outside of Pro Tools. On the Keyboard pane of System preferences you can remap the modifer keys to perform other functions, maybe your command and control keys have been reversed?
Just a guess.
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 02-08-2013, 03:27 PM
[bleep][bleep][bleep][bleep], a program called "Clip Menu" was recently installed on this particular work machine and one of it's shortcuts was blocking Pro Tools shortcuts. Fixed!
Old 02-08-2013, 04:49 PM
DigiTechSupt's Avatar
Post Re: Clear selected clips shortcut not working hd 10.3.2
I could not repro with 10.3.2 or 10.3.3 on OS X 10.7.5, so it did seem like was something local to your setup.
Thanks for following up and letting us know the cause.
Avid Audio Tech Support
Support FAQ
Ungroup Clips Shortcut Not Working? ChazC Windows 6 01-29-2012 03:32 PM
Clear Peak/Meter shortcut not working? theblotted macOS 8 07-23-2011 02:46 AM
Clear all Clips crashs everytime Kurtstudio Pro Tools TDM Systems (Mac) 6 11-27-2005 12:55 PM
Clear all clips crashes, Sometimes! Kurtstudio Pro Tools TDM Systems (Mac) 0 04-05-2005 07:59 PM
Clear selected problem gargoyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-03-2002 03:03 PM
