Old 02-16-2001, 01:27 PM
Craiggo Craiggo is offline
Default Meter question
Couldn't get a good answer over the Digi forum, so I'll try the pros. I'm using PTLE, and I can't figure out exactly what db numbers the little "lines" on the graphic db meters actually indicate. The handbook says yellow (just yellow, middle yellow, all the way to the top yellow?) is -6db...what about the rest of the ref. marks? Just trying to figure out where I stand when something is "light green" or "dark green", etc.
Old 02-16-2001, 03:26 PM
Mt.Everest Mt.Everest is offline
Default Re: Meter question
try this:
First, command-click the volume readout. It will change to show peak readout..
Then click it again without command, and it will reset to infinity zero..
If you have a means of creating a steady tone or sound at a constant volume (oscillator, kybd, tuner, etc) feed that NON varying sound into protools at a low volume at first..
You will see the input level readout where the pk reading is. slowly increase the level and you can see what dB readings display for the different areas of the meter. it will change in realtime to display the input level...again, you can click the readout to reset it..
That should give you an idea of what the colors mean...
victor
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 02-16-2001, 07:01 PM
Thanks for the great response. I'll do exactly this.
Meter display question HB1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-20-2009 02:44 AM
Level Meter Question JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-09-2007 07:07 AM
CPU meter question Cliffy_Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 11-26-2004 02:20 PM
VU meter question viaspiaggia Post - Surround - Video 4 05-20-2004 08:51 AM
Bus Output Meter Question... tomhartman ICON & C|24 1 06-22-2001 12:43 AM
