MP3 vs WAV import / export issue..... - PT HD 12.5.0
Hi DUC guys
I rarely come here - only if I have a problem And almost always the answer is contained within this forum So thank you for that. I'm running Pro Tools HD 12.5.0 on a 2010 12 Core Mac Pro with Antelope audio Orion 32+ converters This issue has plagued me for some time. When sending an MP3 audio file for session musos to record their part to, something goes wrong. When they send their WAV audio file / files back to me it's slightly out of time. I always thought it was their system or something going wrong with their import of my MP3 I finally got clarity with this issue just now after messaging with my session drummer. I've always exported my file as an MP3 due to slow internet They import the file Record to it Then send back their audio which is always slightly out of time. So I exported the same audio file with click printed as both a WAV and an MP3 Then reimported the 2 files back into my session at the same location Look at the image.... Top file is Original 'Bounce' Middle file is Export of MP3 reimported Bottom file is Export of WAV reimported The Wav file imports at the exact same position BUT... the MP3 import is slightly delayed. My deduction.... When Pro Tools exports as an MP3 something funky happens... WHAT IS GOING ON? Has anyone else noticed this? Is it common knowledge? Is there a work around? Has this been fixed in newer versions? Or is it some kind of 'protection' Avid have put in to 'protect' the front of the MP3? HELP PLEASE This has been doing my head in - for quite some time Thanks
https://www.glasshousestudios.com.au Mac Studio M1 Max 32 GB ram macOS Ventura 13.1 24 core Metal 3 GPU Avid MTRX Studio Pro Tools Ultimate 2023.12 HDX card AVID TB3 1 slot PCie Chassis |
Re: MP3 vs WAV import / export issue..... - PT HD 12.5.0
Yes indeed, MP3 files include an extra sliver of time at the beginning of the file. I don't know if it's some kind of "header" in the code, or a metadata chunk, or what, but the result is as you've described.
This is why I always insist that any mp3 audio sent to me for work must have at least one click (or any sound) out in front of the music that can be used as a sync point when importing / exporting / reimporting. I'd be curious to know the technical reason if anybody here knows. WAV and AIFF files don't appear to suffer from this timing anomaly. |
Weird MIDI import/export issue | LukeHoward | Pro Tools 2018 | 1 | 07-17-2018 10:49 PM |
PRO TOOLS EXPORT TO CUBASE IMPORT TIMING ISSUE | Jim Casey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 34 | 07-25-2007 05:22 AM |
OMF Import/Export with PT5.3HD? | Samhein | Pro Tools TDM Systems (Mac) | 8 | 03-28-2002 10:39 AM |
Mp3 import/export | kastlercreative | Digidesign Hardware & Software | 4 | 03-23-2002 05:13 PM |
export/import Q: | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-12-2001 09:44 AM |
