dual monitor - mix and edit on separate windows
Hi
I've been googling this issue for hours now, and it still keeps bugging me: Bought a second display for my macbook pro, running pt 2018.3.0 on a OS 10.13.4 (High Sierra) I can drag my mix or edit window to the second screen and it will sit there nicely while my session is open. But after having saved, closed and upon returning to pro tools, both windows will open on the same screen. This is not the biggest issue in the world and Pro tools is running fine, but I know this should be possible. I just, for the heck of it, can't figure out how to have my display settings saved. I've tried messing about with window configuration list, new configuration and had auto update active configuration on and off... Nothing seems to work though. What am I missing? Best, Jeppe |
Re: dual monitor - mix and edit on separate windows
Hi Jeppe,
I’ve had the same problem before as well. What worked for me is if I slightly resize the Pro Tools windows to be a little smaller so they don’t go to the edge of the monitor screens. If you have the edges of the ProTools edit and mix windows all the way to the edge of the screens I think it can’t tell that they’re supposed to be on different screens and it puts them on the same screen when you restart the session. I can’t say for sure how much I had to resize the windows but you want to see a little bit of your desktop background around all of the edges of the PT windows. Hope that works. Dave
Dave Pro Tools Ultimate 2022.12 / OSX Monterey 12.6.2 Avid HD Omni / HD IO 8x8x8 / HDX Sonnet Echo Express 3 iMac Pro 3GHz, 10 Core, 64 GB |
Hi Dave,
Thank you so much for your suggestion. In the meantime I think I might have stumbled on a different solution, that - at least for the time being - seems to work: Swiping up with three fingers on my touchpad opened "mission control" (Is what I think it's called). I the dragged and dropped the edit window from my primary to my secondary screen, saved it, closed session, opened it up again and... Voila! The edit window sat right where I left it on my secondary screen! I'm sure it'll be gone tomorrow, but for now this solved it for me. Edit: Upon closing pro tools completely and re-opening I was back to square one. Fortunately, a combination of Dave's advice and the mission control trick seems to retain the window placement data, even after a reboot. Last edited by Husmas; 04-04-2018 at 12:52 PM. Reason: Found out more stuff |
mynameischance.com |
Yep, this is what I have to do. It's a pain, but life goes on...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I've had dual 24" before and it was OK, mix on one, edit on the other. Using my MackBook Pro mostly now I got a less than $200 43" 4K TV for a single monitor, if you scale it right it's amazing the way you can spread stuff out and still see. YMMV!
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
It's amazing that I've had to do that same trick in 2021! I've granted PT full disk access to my Mac but nothing worked. I had to do a search here to see what others have done. So yeah, thanks for this tip!
PT Ultimate 2024.3 PT HDX MacPro 7,1 (Intel) 16 Core 96 GB ram macOS Ventura 13.4 Somehow, musicians are now technicians! |
For me, this is one of many signs that Avid is not keeping up. Many things not being taken care of over many years.
I've been using multiple displays on macs since digidesign days and I must say I'm impressed with how the latest versions of macOS are handling displays - and "spaces" nowadays. I have PT "assigned" to my 2nd display (a little known setting found if you right-click on an application in the dock, under "options".) PT remembers to open on the 2nd display, but fails to remember that I have mix and edit on different spaces. Actually, I recently returned a mac mini M1 w/bigsur because of too many small things, like this, not working. The option to "assign" an app to a screen is simply gone in BS. Best tip I've seen is to use "Window configurations". I haven't gotten to it.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
macOS Sonoma 14.2 • Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM • Pro Tools Studio 2023.12, RME Babyface Pro |
Reducing the window size is still needed in Ver 2023.6.0.
Given the subscription being paid every year for "updates", this is sad. |
Mix and Edit Windows on separate monitors | jcirrone | Windows | 15 | 05-11-2017 12:39 PM |
Displays Have Separate Spaces Setting - Dual Monitor Config | accentaudio | macOS | 2 | 01-05-2015 09:02 AM |
Separate show/hide tracks for edit/mix windows | AdHawk | macOS | 3 | 02-12-2014 07:02 AM |
dual monitors separate mix and edit windows? | bonzerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-14-2010 10:24 AM |
5.3.1-Mix and Edit Windows separate? | Targon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 06-24-2002 06:09 AM |
