Re: First Air Instruments Bundle Install fails with Update to PT 2018.1
I have fine pianos from Modartt Pianoteq, Boom, when I first heard it, was ahem not so convincing... I didn't try out "structure free". I am not in a hurry with that, apparently. |
Can you do a Search to see if you've got Structure Free or Structure, or Mini Grand or Boom installed?
These 3 are all you get in the First Air Instruments Bundle. Xpand!2_18.1 has its own separate Installer. If you have earlier versions of Structure Free, Mini Grand, Boom and Xpand!2 installed, they should be uninstalled before installing the latest version. Save your User Presets to the Desktop (or wherever) - these can be added to the new Presets later Search for a Mac equivalent to this article: How To Perform A Clean Removal Of Pro Tools 11 or 12 Ready To Install A Newer Version On Windows Posted on November 26, 2015 by Neil Hester http://www.pro-tools-pc.com/how-to-p...ools-11-or-12/ Once you're "clean as a whistle" - download & open First AIR Instruments Bundle 18.1 Installer (Mac) 1.06 GB On Windows, there's a Content Installer, as well as the App
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 |
'tis about 5:20 am here, so I gotta go - but I will check back later. Good luck!
Had an easy night of installing - the 3rd-Party stuff can wait 'til tomorrow. Little bit bushed, 'cos it was about 104° F here yesterday
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 Last edited by unkJE; 07-04-2021 at 10:28 PM. |
Thanks for the info... For all users of the full version of Structure...Be careful with the 2018.1 update for Air instruments bundle. It installs Structure Free, but the filename is the same as the full version, so it overwrites the full version.
What i did, was to move out the Structure.aaxplugin of the plugins folder. Then i installed the Update. Then i moved the full version back to the plugins folder, overwriting the Structure Free plugin (which has the same filename:structure.aaxplugin) |
By this time, First Air Instruments and FX work fine, thanks for answering.
But I now face trouble with another bundle: Black Shiny Wah, Black Op Distortion, Black Spring appear in my application manager, but when I try to use them in a PT session, the do not show up in the inserts list. This time, I feel I could really need to use at least one of them relatively soon. (Please see also my post in http://duc.avid.com/showthread.php?p...41#post2482541 But not solved yet.) I have a case opened about this, they suggested a remote session, but I don't see how that would happen. How will the contact be established, by which application? How will I know, when? Please, if anyone could update me either about the remote session, or about the not useable plugins, I'd be very thankful. Meanwhile you might try and enjoy a track I made with a singer living in Zimbabwe: https://soundcloud.com/werner-linden...oing-to-travel (The first part of the tiltle being translated in the second half.) Last edited by Wire57; 03-30-2018 at 10:02 AM. |
Lost HEAT in 2018 Install | zeeman | Pro Tools 2018 | 14 | 11-23-2019 12:35 PM |
2018 | install plugin path? | chip_nelson | Getting Started | 8 | 03-31-2018 04:37 AM |
How to install virtual instruments bundle | herpergerleon | Getting Started | 1 | 03-19-2016 09:58 AM |
First AIR Instruments Bundle fails to DL from Application Manager | caliheights | Virtual Instruments | 1 | 01-03-2016 02:00 AM |
PT 8 Re-Install Fails | MarmotMusic | macOS | 1 | 10-20-2012 03:19 PM |
