ProTools 10 and quad core i7 mac mini!!
WHat do you guys think, Do you think ill have any problems doing large sessions? Currently im running protools le 8.5 with a digi 003 factory + and the music production toolkit 2. All my sessions are on a PC unfortunately that can not handle all the new stuff im doing with editing, replacing, melodyne etc lol
So i will need to put these sessions on the new computer. My other option is to buy a older used 2008 or 2009 mac pro 8 core with slower old ramm, What do you guys think?? Thanks in advance for everything!!! |
Re: ProTools 10 and quad core i7 mac mini!!
My new Mac mini quad i7 @2ghz benchmarks 50% than my 2009 Mac pro 2.6ghz
that should tell you the performance is way better and if you need PCIe slots the magma thundbolt chassis will be available in a couple months
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Just got one. I normally mix with high buffers doing long form work, and it is very very powerful. Though you can notice the lack of a graphics card (it does handle h264 video just fine.. but other aspects are.. sluggish at times...)
Matt Perrott Sound Designer and Engineer Sydney, Australia |
Thats fantastic!!! I just loaded everything up and got my 003 working, everything seems to be running fine, I had to reduce my buffer size to 32 for my hardware to work, is that normal??
Im up to 10.01 on lion 10.7.3. I had to go through avid site to find all my old plug in from le 8 they all loaded up no problem. Im just missing my virtual instruments that came with protools le 8 and i cant find where to dl them from avid?? Any suggestions. Thanks for all the help guys!! |
It is the Mac Mini Quad core i7 server with 4 gb ddr3 1333mhz ram, and 2 500gb 7200rpm HDs.
Have you guys upgraded the ram yet. Should i go full 16gb, its surprisingly cheap for all that ram! |
Hi
Since two days i have the new Quad Mac Mini Server with 16 GB Ram. Protools 10.0.1 and CPK I am able to load every session from the big room without error. That is currently 205 Tracks with a lot of surround busses Even with reduced cores to 5 everything runs very very smooth. Graphics is absolutely fast enough. No 9xxx errors so far. I did not deinstall the Server options. Just as it came! Go for it. Works!!! Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
Apple Mac Mini Core i7 2GHz QUAD CORE - 4GB RAM - 2 x 500GB | gsilbers | Buy & Sell | 3 | 05-18-2013 05:17 PM |
What's with multiple processor list when using Mac Mini Quad Core? | Loopagator | Pro Tools 10 | 3 | 05-06-2013 08:51 AM |
new mac mini quad core 2.6ghz | Fourtsian | macOS | 1 | 03-12-2013 08:24 AM |
Which Mac Mini: 2.7 GHz Dual-Core or 2.0 GHz Quad-Core??? | ProMac07 | Pro Tools 9 | 17 | 01-02-2012 06:56 PM |
ProTools with Core 2 Quad 9650 help! | Grizz1978 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 09-28-2009 11:59 PM |
