protools 9x Audio Track Record/Lock
I just discovered that non HD based protools systems do not have the " Audio and Transport record lock" Feature. That's a Bummer! I'm guessing the only systems that offer this are Native systems and HD?
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
Re: protools 9x Audio Track Record/Lock
Do you mean this? The manuals does not say it is an only HD feature. TrackPunch is HD only.
"Loading Dailies Using RecordLock Foley Recording Dailies and similar types of transfers are comprised of multiple takes or scenes, each recorded while locked to unique time-of-day time code. In between each take, time code does not continue but stops completely. Because of this, the time code on dailies and similar source material is said to be “discontinuous” or discontinuous (also known as broken time code). By default, Pro Tools drops out of recording when it goes offline due to broken time code. However, you can change this behavior so that Pro Tools will instead remain armed, waiting to begin recording again when lock is re-established with the time code of the next take." Page 505 of the manual But Transport Record Lock is HD only: Transport RecordLock (Pro Tools HD Only) This option lets the Transport Record (the Record button in the Transport controls) be configured to either emulate a digital dubber, or to maintain legacy behavior for the Transport master Record. • When selected, the Transport Record remains armed when playback or recording stops. This saves having to re-arm the Transport between takes, emulating digital dubber behavior. • When not selected, the Transport Record disarms when Pro Tools is manually stopped or stops due to a loss of time code. This replicates standard Pro Tools recording behavior. Page 123
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Unable to Record (digitize) a Regular Midi Track to an Audio Track | JuicyMusic | macOS | 9 | 02-27-2013 08:52 AM |
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
Record more than one Midi track in protools 8 | fastgreen | MIDI | 0 | 10-30-2009 11:46 AM |
Preferences: Audio Track Record Lock | Toe Jam | Pro Tools TDM Systems (Mac) | 3 | 03-25-2005 04:55 PM |
How do I record a MIDI track onto an audio track? | shemcom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-11-2003 06:13 AM |
