Old 11-24-2007, 10:56 AM
joviyan joviyan is offline
Default Reverb Recommendation Needed!
New PTLE user here...
I recently bit the bullet and upgraded from Cubase SX on Windows Virus...I mean Vista (sry...=P) to PTLE 7.3 on an OS 10.4.9 box. Been recording 4-16 part TTBB Mens Acapella stuff for about 10 years, but my favorite reverb, a little obscure gem called "Ambience" by Magnus Jonsson (http://magnus.smartelectronix.com/) isn't available in RTAS format.
I need a new reverb - the best one that I can find. I have always used my reverb for real-time monitoring in addition to mixing and mastering - as the pieces that I produce are overdubbed one track at a time. The effect of the reverb takes the edge off of laying solo vocal tracks. I have fallen head over heels for PTLE, but trying to get the job done without a good verb is painful to say the least...
Any recommendation for an excellent software or hardware reverb plugin (price is irrelavent) that has, most importantly, the analog warmth we all love, would be VERY appreciated. Thanks in advance.
Cheers,
Joviyan
PTLE7.3; OS 10.4.9,2.8 Ghz Intel C2 Extreme,4GB, Avalon Vt 737sp, Neumann TL49, 003 Digi rack
Old 11-24-2007, 12:42 PM
mindnoise mindnoise is offline
Default Re: Reverb Recommendation Needed!
HI,
the best is Sony Oxford Reverb, IMHO.
even beats Altiverb by a nuance.
if you want hardware the get a $12000 lexicon or so it won´t get any better
regs
last: PT11.3.1
Old 11-24-2007, 12:57 PM
Awesome - i'll check that out asap
Thanks again,
Jov
Old 11-24-2007, 04:13 PM
SeedGuy SeedGuy is offline
You could of course get the VST to RTAS adapter from FXpansion.
Thats if you would really prefer to use the reverb you mentioned.
Old 11-24-2007, 05:08 PM
sw rec sw rec is offline
I have been having GREAT success with Masterverb 5 from Wavearts (www.wavearts.com). You have adjustments for every imaginable parameter and it's not a resource hog.
To run on LE you'd have to use the FXpansion adapter, but the plate and room reverbs from Princeton Digital seem to be highly respected as well. (www.princetondigital.com) Haven't tried these. Yet.
I also really liked the reverbs from Sonic Timeworks when I was running SAW Pro. (www.sonictimeworks.com)
Old 11-24-2007, 06:59 PM
There are several reasonably priced plugins that work well. Waves bundles with Rverb and TrueVerb are decent but a little odd to edit. IK Classik verbs are also very useable and can run under a sinple editing format or you can dig deeper if you need it.
Old 11-24-2007, 10:05 PM
StavrosSound StavrosSound is offline
I cast a vote for the Waves IRx. I haven't had much experience with Altiverb or the others listed, have minimally used TL Space... but IRx holds it own rather well and comes with a ton of pre-made responses. When push comes to shove, it's really saved some delivered ADR I wasn't expecting would be able to sit into the mix very well.
Overall, the best option would go for a convolution reverb (like IRx or Altiverb or TL Space). Some plugins such as RVerb and True Verb use algorithms to create reverberation; in the real world, phasing issues do occur and give a distinctive timbre to reverberation, say, between a church or a car interior, that many of these mathematically precise plugins cannot easily emulate. Convolution reverbs use a captured response (generally a tone, pink noise, and/or soe sort of frequency sweep), and capture near exact characteristics of a setting, including its phase issues.
It really depends on what your needs are. For film, convolution is the new digital trend. For music, algorithm-based plugins may for better for a more fully rounded, even timbre.
Oh, and speaking of convolution, look up Speakerphone by AudioEase. A very creative and mind blowing way of using impulse responses for futzing purposes!
"White noise- the birth cry of the universe."
IMDb Credits
Old 11-25-2007, 08:14 PM
Wow - thanks all for the overwhelming response! I feel much more equipped to make a good choice....wish me luck
Cheers and thanks again:)
Jov
Old 11-27-2007, 04:34 PM
humpback humpback is offline
For a hardware reverb unit, I'd recommend this. Used it on a recent project (a beta unit.... the final production one has to be even better)... simply unbelievable. Pricey, but absolutely worth it.
Best
Nathan Lowe
Studio:
Mac Mini 2.6 GHz i7
16GB RAM
PT 2019 and 10.14
UA Apollo Quad
Outboard:
2 x Summit Audio 2BA-221>TLA 50>EQF-100
2 x dbx 165a
4
x Shadow Hills GAMA
http://humpbackmedia.net[/SIZE]
Old 11-29-2007, 05:41 PM
davegibbon davegibbon is offline
I found this post helpful too. I have been looking for an improvement on the standard Digi reverbs. Can anyone tell me the absolute minimum get an improvement over D-verb? I lean towards hardware but I'd consider software.
Thanks
Dave
reverb recommendation vudoo Post - Surround - Video 10 09-24-2012 05:03 AM
Educational Purchase Recommendation Needed vids Pro Tools 9 1 02-08-2011 07:14 AM
Looking for a reverb plug-in recommendation yin7yang64 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-28-2007 09:54 PM
Repair recommendation needed amiller ProControl, Control|24, Command|8 1 02-27-2004 06:45 PM
Outboard Reverb Recommendation pxpx83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-25-2003 12:19 AM
