Digi002, metering the inputs
Will the LEDs on the rotary encoder be able to monitor the inputs ?
Will I, as an example, be able to set the gain of a preamp for a microphone using the meters ? Thanks, Nat |
Re: Digi002, metering the inputs
Yes they will moniter the inputs. if i am not mistaken they will serve many different purposes, just like v-knobs and leds do on digital boards.
Christian |
Thanks, glad to hear !
I saw that in the answerbase that the meters were only post fader, meaning you can't monitor the inputs, is that true ?
Digi ? |
When in Pro Tools mode, the meters reflect the mode chosen in the software. In other words, if Pre Fader Metering is chosen under the Operations menu, the LED arrays on 002 will show pre-fader levels. If this is not chosen, they will show post fader.
In standalone mode, the meters are always post-fader. |
Thanks a lot !
DIGI002 ADAT inputs - 96k? | roryrok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-16-2014 10:05 AM |
HELP! using 8 inputs on Digi002? | bustedacres | Getting Started | 12 | 10-27-2013 09:29 AM |
Why only 2 inputs on my Digi002? | wfenlon | macOS | 11 | 05-06-2012 01:07 PM |
Digi002 XLR inputs strictly mic? | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-18-2009 09:57 PM |
Connecting to inputs 5-8 on my digi002... | JoyMODE101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-10-2007 02:03 PM |
