Old 01-25-2024, 03:25 PM
Thousand Words Thousand Words is offline
Default Field Recorder Workflow Eucon command?
Is there a Eucon command for toggling through the mics in field recorder workflow?
Old 01-26-2024, 09:14 AM
Default Re: Field Recorder Workflow Eucon command?
Sounds like a good idea, if this doesn't already exist.
Scott Gatteño
Old 01-27-2024, 05:31 AM
Felix Rost Felix Rost is offline
I have no direct answer, but: If there is a Keyboard Shortcut in Pro Tools available you can assign a Key Command in Eucon to those keys.
http://felixrost.de
Old 01-29-2024, 03:04 AM
Ayush Ahuja Ayush Ahuja is offline
Cmd + Opt Up/Dn scrolls through field recorder channels if FR is enabled and correctly matched on a track.
You can easily add this to any of the custom keys though it seems easy enough to access this on the keyboard?
PT Ultimate 2023.12, MacStudio M1 Ultra 64GB RAM OSX 13.1, Avid MTRX Studio, Avid S1/Dock + VideoSync 5, MacMini 3.2GHz i7 64GB RAM OSX 10.13.1
Old 01-29-2024, 06:36 PM
Thanks, Yes I realized I could program a key command on a soft key in Eucontrol. It's a lot faster to put the commands I use a 1000 times a day to a single hand action, all grouped on a user page of soft keys.
HTML code is On
Field Recorder Workflow with Live PT sessions as Field Recordings SlickSlack Post - Surround - Video 9 11-10-2022 05:45 AM
Field Recorder Workflow Cheesehead Post - Surround - Video 6 02-14-2018 02:54 PM
Field Recorder Workflow pls help! jahtao Post - Surround - Video 4 03-27-2014 05:04 PM
Field Recorder Workflow & PT 9.0.2 Tom Graham Post - Surround - Video 8 03-20-2011 11:39 AM
