Old 11-13-2023, 12:05 PM
ryst ryst is offline
Default Dialog Bus in a 5.1 Mix - Mono, 5.0, 5.1?
Hello everyone,
I read on these forums that some people just have a mono dialog bus in their 5.1 mixes. I've also read where other people have a 5.0 or 5.1 dialog bus.
I assume if you're routing your dialog to a mono dialog bus that all your verbs are mono too? I generally route all my dialog verbs to the dialog bus.
Is there an advantage to having a mono dialog bus as opposed to a 5.0/5.1 bus? Or is it just personal preference?
Thanks!
Old 11-13-2023, 02:03 PM
SonicSloth SonicSloth is offline
Default Re: Dialog Bus in a 5.1 Mix - Mono, 5.0, 5.1?
You'll get a lot of varied replies on this one. It's partially a taste thing. A mono DX bus will save a little bit of processing power, but I'm not sure it's all that necessary these days, and I'll be easier to pan dialogue when you need to (although that is certainly rare-ish). No point in having a 5.1 DX bus though, 5.0 is all you'll ever need. Chances are if you ever feel the need to put dialogue in the LFE, there will be a VERY specific reason and you'll probably create a bespoke template for that mix.
For verbs, I find that mono dialogue verb does sound best when you're just using it to match lines and tone, but a 5.0 reverb is great to have if you're using it to create a sense of massive space, like a character shouting in an empty church, etc. But again, this can all be chalked up to taste.
Old 11-15-2023, 02:43 AM
EarHole EarHole is offline
I just use a 5.1 Bus for consistency. Certainly not needed.
Old 11-15-2023, 05:36 PM
Led Led is offline
I always thought 5.0 was all I needed for a DX bus, but then Dune..
Old 11-15-2023, 07:40 PM
audiolex1 audiolex1 is offline
Multiple mono verbs on hand. And some stereo and a 5.0 for different sorts of environments when you want a complete 360, but sometimes its too much when you just want to feel the size in the back or sides.
5.1 bus nowadays is just easier to setup with everything. Run across an underwater scene it gives some thickness.
But its a rarity.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 11-20-2023, 08:51 AM
Brandonx1 Brandonx1 is offline
I just make the widest delivery dial stem. If a network asks for 5.1 dial stem, that's the dial bus I make. Even if it's only coming from the center channel.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 11-25-2023, 11:40 AM
kosmokrator kosmokrator is offline
this.
Old 01-17-2024, 04:21 PM
yazoo yazoo is offline
Never figured out Master Link button.
If you have a 5.1 channel and change the channel selector to center and have Master Link enable does this mean that the C is the key source and the rest of the channels follow that level (if you have a compressor on the channel)?
All the best
Benny
Old 01-17-2024, 06:58 PM
its2loud its2loud is offline
You have to unlink the channels in the plugin. Otherwise all the channels of the plugin will follow the same settings. Selecting the channel view only shows you the settings for that channel of the plugin.
Old 01-17-2024, 09:12 PM
Tone_Mechanic Tone_Mechanic is offline
All the best
Benny
If you are using a multi-mono instance of the plug-in, then they do not share sidechain key sources. The master Link button allows you to gang the controls so that the settings are the same on all channels, but it operates like six mono compressors that all have unlinked sidechains.
In other words, in a multi mono instance of the plug-in, level changes on the C channel will not cause compression to occur on the L or R or any other channel.
HTML code is On
signal routing - mono audio to multi-mono plugin christien Pro Tools 7 06-21-2023 01:01 PM
Moving plugins from mono to stereo..then back to mono... Big_Beast_Music Avid Pro Mixing General Discussion 9 12-22-2022 12:01 PM
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Compress 76:30 mono dialog to 73:30 ? Erinugene Pro Tools TDM Systems (Mac) 6 10-03-2006 07:25 PM
