Old 07-02-2012, 07:27 PM
stormmusic stormmusic is offline
Default Duplicate command no longer works on automation???
BEFORE 10.2.0 I could draw a nice volume ride and then copy/paste or duplicate it anywhere else in the track ( rather than draw the thing again) now when I select the fade and "copy" or select then hit DUPLICATE nothing happens? Any one else see this? new setting I have to change or automation bug?
Old 07-02-2012, 10:51 PM
mr.armadillo mr.armadillo is offline
Default
"Automation follows edit" is on?
Old 07-03-2012, 02:39 AM
simonchase simonchase is offline
Default Re: Duplicate command no longer works on automation???
I've been having this sporadically
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 07-03-2012, 07:16 AM
Giftofsound Giftofsound is offline
Default
Yet another reason we will avoid upgrade our larger rooms to 10 for some time
Matt R. Sherman
Re-Recording Mixer/Sound Editor
http://www.giftofsound.ca
Old 07-03-2012, 07:46 AM
Not sure what you mean, works fine here. Copy/paste and apple-d.
Old 07-03-2012, 08:40 AM
so with AUTOMATION FOLLOWS EDIT it works but I never had to have that selected before?
Old 07-03-2012, 09:11 AM
Haven't tried it with auto follows off. Should not matter since you are simply copy/pasting curve data. You're not editing the clip itself.
Old 07-03-2012, 11:41 AM
exactly my thoughts BUT it will not copy any automation without the AUTO FOLLOWS EDIT thing selected.
Old 07-03-2012, 02:38 PM
uhhhhh NOW command + space bar doesn't make PT record??
Also, I've found digisetup file in the hidden library folder but where are pro tools prefs?????
Old 07-03-2012, 09:15 PM
doug_hti doug_hti is offline
ugghh. Just had to search why i could no longer simply copy volume automation from a stereo aux to another stereo aux. Restarts later, I do a search and land here.
Follows automation works...then I have to turn it off again...
Doug
HTML code is On
spdif no longer works on 8.01 latiffee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-30-2009 06:46 PM
PT LE 7.4 no longer works on 3 different PCs AlyssaG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-19-2008 11:27 AM
D-command duplicate playlist problem mtung ICON & C|24 0 03-17-2008 01:37 PM
MAJOR BUG with Duplicate command 6.9.2 Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-21-2005 02:25 PM
CMD- SPACEBAR no longer works !!.. Lo Pro Tools TDM Systems (Mac) 5 05-30-2000 07:29 PM
