Old 05-03-2012, 07:11 PM
wfenlon wfenlon is offline
Default Why only 2 inputs on my Digi002?
Why do I only have "Built in Microphone1 and2" or "Line input 1and2" inputs when connected to my Digi002? I thought I should be able to have at least eight active inputs at a time. Under setup-I/0, the input only lists those options
as available? Thanks.
Mac osx snow leopard
Digi 002
firewire connection
ProTools 9.04.06
Old 05-03-2012, 07:15 PM
Craig F Craig F is offline
Default Re: Why only 2 inputs on my Digi002?
sounds like your looking at the computers I/O
what is your setting under Playback Engine
Thank you,
Craig
Old 05-04-2012, 07:33 AM
The playback engine reads "Digi002"-which seems correct.
Old 05-04-2012, 08:19 AM
daeron80 daeron80 is offline
Where are you seeing those inputs listed? The I/O selector in the Mix window of Pro Tools?
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 05-04-2012, 10:41 AM
nst7 nst7 is offline
Go into your I/O setup page and click "default" on each of the tabs.
Old 05-04-2012, 12:06 PM
dobro dobro is offline
Jep done that sevel times it works,..... in´s and out´s
Old 05-04-2012, 11:27 PM
YYR123's Avatar
YYR123 YYR123 is offline
So did the OP fix his issue.....Then change his identity or did i miss something?
Daniel
Old 05-05-2012, 04:47 PM
Thanks to all trying to help. I tried to reset my IOs to Default in the Set up for Protools 9 but nothing happened when I click default.
Old 05-05-2012, 06:21 PM
can you post some screen shots?
Thank you,
Craig
Old 05-05-2012, 08:52 PM
OK. I went back to the Playback Engine and it now read ProTools Aggregate instead of Digi002. I changed it back again to my interface and THEN I could default the I/Os. Great! But...
Now my first audio track input is grayed out and reads as follows:
Builtin microphone 1 (mono) path inactive
Builtin microphone 2 (mono) path inactive
Built in input 1 (mono) path inactive
MicLine 4 path (mono) path inactive
Analog 5 (mono)
Analog 6 and analog 7 are in yellow
Audio 1 track Output is now Blt-n Otput1-2
Audio 2 track Output is now Analog 3-4
Why are the first 4 paths inactive when hooked up to the Digi002?
I guess somebody jumped in on the thread who had a similar problem
DIGI002 ADAT inputs - 96k? roryrok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-16-2014 10:05 AM
HELP! using 8 inputs on Digi002? bustedacres Getting Started 12 10-27-2013 09:29 AM
Digi002 XLR inputs strictly mic? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-18-2009 09:57 PM
Connecting to inputs 5-8 on my digi002... JoyMODE101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-10-2007 02:03 PM
Digi002, metering the inputs Flying 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-26-2002 05:01 PM
