Old 03-23-2012, 11:53 AM
redbull redbull is offline
Default Pro Tools 9 keep jumping to end of Mix/Edit screen
I have a very annoying problem that started yesterday and I can't track down the reason.
Every 10 seconds or so, whether on the Edit or Mix screen, the page will just jump right to the end..so in the case of the Mix screen it will jump all the way to the right, and in the case of the Edit screen jump all the way to the bottom.
Even if I'm in the middle of holding a fader down, it will still jump. Very annoying.
I'm 99% sure it has nothing to do with my mouse, doesn't happen in any other program, and the fact it jumps vertically as well as horizontally rules the mouse out I think.
The track at the very end of the session I'm working on has a blue box around it's name, I have a feeling this might have something to do with it, but having never seen it before I can't figure it out! Probably something obvious I've done accidentally...can anybody help?
Old 03-24-2012, 06:02 AM
PD-John PD-John is offline
Default Re: Pro Tools 9 keep jumping to end of Mix/Edit screen
Because of the blue box comment, I'm taking a wild guess... Check that there's no controller selected under Setup > Peripherals > MIDI Controllers (set all the "Type" menus to "None" unless of course you use a controller).
Old 03-25-2012, 12:04 PM
Yes the problem turned out to be my M-audio USB keyboard. I've never had a problem with it before, but disconnecting it sorted it out. Thanks for the reply.
Edit window jumping around benderbro Pro Tools TDM Systems (Mac) 3 12-27-2022 03:25 AM
Vertical Jumping With Edit Selection In Playlist View soundlabyrinth macOS 11 09-24-2012 06:37 PM
PT 8: how to edit while its playing without playback jumping to where you click? marcnyc Pro Tools M-Powered (Mac) 3 12-25-2008 11:05 AM
Mouse pointer jumping around screen crizdee Pro Tools TDM Systems (Mac) 6 09-27-2005 01:03 AM
Burn CD straight from pro tools P&Q edit screen bobbie_wise@yahoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-20-2004 07:37 PM
