Old 03-21-2010, 02:40 AM
djryno djryno is offline
Default Command 8 Meter adjustment??
Is there any way to boost the command 8 led meters?
I record and mix pretty low. So, I can't really tell what tracks are playing, when they are playing, just by looking at the board.
Thanks!
- Ryno
Old 04-02-2010, 08:59 AM
foabiacc foabiacc is offline
Default Re: Command 8 Meter adjustment??
Is there a reason you record at such low levels? Signal to noise ratio is better when you feed a measurable signal (i.e. visible on the VU meters) to the channel on which you're recording. If it's too loud, try turning down the power amp running your monitors or insert a master fader and pull it down.
Inserts affecting send meter but not channel meter? Kbrinson85 Windows 1 05-01-2012 07:00 AM
PT 10.1.2 D-Command meter issue Audio_Vision ICON & C|24 1 04-26-2012 10:50 AM
PTHD8 cpu meter vs task manager cpu meter MEAT Pro Tools TDM Systems (Win) 5 01-02-2009 05:17 AM
Can D-Command show Gain Reduction on the Meter Bridge? macaholic ICON & C|24 3 02-13-2008 12:28 PM
How do I reset the meter on Command|8? mrllnfn ProControl, Control|24, Command|8 3 03-17-2007 05:17 PM
