RAM usage is over 1.3GB on a simple session...normal?
MEM USAGE: 1,279,544 K
isn't this a bit excessive? http://cyrusghahremani.com/misc/WTF.jpg this is the session: http://cyrusghahremani.com/misc/session.jpg running on a core2duo 6600 windows xp pro sp2 / protools 7.4 2gb of ram, running on a brand new Seagate Barracuda 205gb w/ 32mb cache session is on a separate drive - a samsung 160gb, 7200rpm standard i've done reinstallations and reformatted. i don't know what's up here. |
Re: RAM usage is over 1.3GB on a simple session...normal?
Well you have 3 amplitube's running. That's why.
When using guitar emulation plugs, the way to use them is to add the plug-in to an aux track, with the input set to your guitar line in, then set the output to an available buss and record the affected guitar track to a new audio track, and keep repeating this for how many guitars you need, only using ONE instance of amplitube. Guitar emulators use a lot of system resources, so only use ONE per session. And you also have 3 Dverbs running as inserts. Do you know how to set up SENDS for reverb (and other FX by the way), rather than using as an insert on the actual track? This is probably not the case for your RAM, as it's normal to have 3 Dverbs running as sends, but start using sends instead for your FX. |
How much memory usage does your PT take up on normal launch ? | hwill2008 | Pro Tools 9 | 2 | 04-27-2011 07:11 PM |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
7.4 RTAS Usage meter higher than normal! Any thought's? HELP | TREXROCK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-26-2007 12:37 PM |
system usage window... is this normal...? | drmmrboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-06-2007 03:17 PM |
Anyone use SiS chipset? Normal CPU usage? | illfi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-15-2002 08:22 AM |
