How to use ALL 18 inputs on Digi002 without jitter
I´ve written some questions about thi in the past and got some answers but I wanted it confrimed by my dealer before getting a a S/PDIF converter, and my dealer wasn`t shure either.
How can I connect 8 Channels of Adat and an S/PDIF to my 002R and get everthing clocked without getting digital pops and/or jitter?
Stian Sylta Producer/Songwriter/Musician Sons Of Vanity on iTunes/Spotify MacBook Pro i7/Apogee One/Duet/ElevenR/Pro Tools 12 Preamps from UA, Mackie and Avid. Listening through Dynaudio, Genelec and ADAM |
Re: How to use ALL 18 inputs on Digi002 without jitter
Connect the ADAT convertor's Optical litepipe to the litepipe input on the 002 and set the ADAT converter to "Internal Clock" and in hardware settings, in Protools, select ADAT as clock source. Then connect the ADAT convertors Sync out (wordclock out) to the S/PDIF pre's sync input (wordclock in) with a 75ohm coax sync cable. Select external sync on the S/PDIF pre. Connect the S/PDIF pre's Digital output to the 002's S/PDIF input.
Now the ADAT acts as the master clock and Protools and the S/PDIF are in slave mode. Swiching the sample rate on the ADAT interface should now update the sample rate on the S/PDIF interface and Protools. |
HELP! using 8 inputs on Digi002? | bustedacres | Getting Started | 12 | 10-27-2013 09:29 AM |
Why only 2 inputs on my Digi002? | wfenlon | macOS | 11 | 05-06-2012 01:07 PM |
Connecting to inputs 5-8 on my digi002... | JoyMODE101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-10-2007 02:03 PM |
Digi002, metering the inputs | Flying | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-26-2002 05:01 PM |
clock jitter mapped against the jitter in your CD Players DAC | sessiondude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-30-2002 07:02 PM |
