Old 01-10-2006, 07:27 AM
savage savage is offline
Default PT doesn\'t Doesn\'t Draw Some Waveforms
Annoying problem slowing my work:
PT 7 stopped drawing waveforms in some recorded files. Other files recorded earlier, and some smaller files, don't have this problem. Some files have waveforms the first minute or so - then waveform is lost. There's no change in the sound of the files that is OK whether there's a waveform or not.
I tried:
Check prefs re. redraw, then close down, delete Digidesign Databases on all drives, and delete DAE prefs, DIGi set and PT prefs. Also I repaired permissions.
The problem persists.
Editing without waveforms is like doing tape without the charms of the tape.......
Please advise, DIGI or anybody else who knows about this. Thanks.
PT 7
HD3 accel
Powerbook 17" 1.5 Ghz
1.5 GB Ram
Rosetta 800
Old 01-10-2006, 08:15 AM
DigiTechSupt's Avatar
Default Re: PT doesn\'t Doesn\'t Draw Some Waveforms
Is this happening in one particular session or all sessions?
What type of drives are your audio files stored on? Try doing a 'save session copy in' and copy all media, then open the copied session - are the waveforms still missing?
Avid Audio Tech Support
Support FAQ
Old 01-10-2006, 08:29 AM
jeremyroberts jeremyroberts is offline
How do you clean the grease pencil off the LCD?
--Jeremy
Old 01-10-2006, 12:21 PM
Which record mode are you using when you have the waveform drawing issue? Try using QuickPunch.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Problem with draw waveforms audioplace estudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-17-2008 12:32 PM
why doesn't a fade always draw in on 6.1 JAL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-26-2004 11:00 AM
Digitranslator 2.0 doesn't draw waveforms??? Drew Pro Tools TDM Systems (Mac) 8 07-21-2004 08:35 AM
Draw waveforms rectified - bug in 6.4? wolfman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-22-2004 11:47 AM
Can't draw out clicks benderbro Pro Tools TDM Systems (Mac) 9 01-07-2003 05:57 AM
