sandra report
I bought an accel card that isn't working in my set up. Are there any other tests except digitest to verify that the card is in deed faulty?
I don't want to ship it back unless Im sure it's broken. WIth the accel card installed I get error 4 then 9003 when loading Pro tools. Digi test won't even start with the accel. I tried swapping the core card with the accel. same error. I uninstalled accel card and digi test works fine with core card. ANy help is greatly appreciated Follows is my sandra report. SiSoftware Sandra ID Host Name : ae-c11b10cc6eb1 Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Serial Number Chassis : Chassis Manufacture Tower Mainboard : ASUS K8N-DL Serial Number : 123456789000 BIOS : Phoenix Technologies, LTD ASUS K8N-DL ACPI BIOS Revision 1008 02/17/2006 NUMA Support : 2 Unit(s) Total Memory : 2.5GB ECC DDR Registered Processors Processor : Dual Core AMD Opteron(tm) Processor 265 (2C 1.81GHz, 1.81GHz IMC, 2x 1MB L2) Processor : Dual Core AMD Opteron(tm) Processor 265 (2C 1.81GHz, 1.81GHz IMC, 2x 1MB L2) Chipset Memory Controller : ASUS nForce4 Memory Controller 2x 1GHz (2GHz) FSB Memory Controller : AMD Athlon 64/Opteron HT Hub 2x 1GHz (2GHz) FSB, 2x 1GB ECC DDR Registered 2x 201MHz (402MHz) Memory Controller : AMD Athlon 64/Opteron HT Hub 2x 1GHz (2GHz) FSB, 512MB ECC DDR Registered 2x 201MHz (402MHz) Memory Module(s) Memory Module : OCZ OCZ400512SSER 512MB ECC DDR Registered PC1-3200R DDR1-400 (3-3-3-8 2-11-0-0) Memory Module : Kingston 512MB ECC DDR Registered PC1-3200R DDR1-400 (3-3-3-8 2-11-0-0) Memory Module : OCZ OCZ400512SSER 512MB ECC DDR Registered PC1-3200R DDR1-400 (3-3-3-8 2-11-0-0) Memory Module : Kingston 512MB ECC DDR Registered PC1-3200R DDR1-400 (3-3-3-8 2-11-0-0) Memory Module : OCZ OCZ400512SSER 512MB ECC DDR Registered PC1-3200R DDR1-400 (3-3-3-8 2-11-0-0) Video System Video Adapter : NVIDIA GeForce 8400 GS (8 SP 1.35GHz, 512MB DDR2 798MHz 64-bit, PCIe 1.00 x16) Graphics Processor Storage Devices Maxtor 6Y120P0 (123GB, ATA133, 8MB Cache) : 114GB (C:) (D:) WDC WD10EARS-00Y5B1 (1TB, USB2/SATA300, 3.5") : 932GB (H:) HL-DT-STDVD-RAM GH22NP20 (8.5GB, ATA66, DVD+-RW, CD-RW, 2MB Cache) : 8GB (E:) Logical Storage Devices Partition 1 (C:) : 57GB (NTFS) @ Maxtor 6Y120P0 (123GB, ATA133, 8MB Cache) Partition 2 (D:) : 57GB (NTFS) @ Maxtor 6Y120P0 (123GB, ATA133, 8MB Cache) Pro Tools HD (E:) : 8GB (CDFS) @ HL-DT-STDVD-RAM GH22NP20 (8.5GB, ATA66, DVD+-RW, CD-RW, 2MB Cache) Floppy Disk (A:) : N/A New Volume (H:) : 932GB (NTFS) @ WDC WD10EARS-00Y5B1 (1TB, USB2/SATA300, 3.5") Peripherals LPC Hub Controller 1 : ASUS nForce4 ISA Bridge LPC Legacy Controller 1 : Winbond W83627THF/THG Audio Device : ASUS nForce4 AC'97 Audio Controller Audio Codec : Realtek Semi 0090h Audio Device : AVID Tech 56361 Audio I/O Controller (MIDI) Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS nForce4 Memory Controller Disk Controller : ASUS nForce4 Parallel ATA Controller Disk Controller : ASUS nForce4 Serial ATA Controller Disk Controller : ASUS nForce4 Serial ATA Controller Disk Controller : ASUS SiI 3114 SoftRaid 5 Controller (ASUS 8136) USB Controller 1 : ASUS nForce4 USB Controller USB Controller 2 : ASUS nForce4 USB 2.0 Controller FireWire/1394 Controller 1 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : nVidia MCP2 SMBus 1 SMBus/i2c Controller 2 : nVidia MCP2 SMBus 2 Network Services Network Adapter : Broadcom NetXtreme Gigabit Ethernet - Packet Scheduler Miniport (Ethernet) Network Adapter : Belkin F5D8053 N Wireless USB Adapter #2 - Packet Scheduler Miniport (Ethernet, 72Mbps) Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance : x86 |
Re: sandra report
have you got the ribbon installed correctly, it's quite easy to connect this up wrong when you start swapping the card order....
Re: sandra report
the ribbon is pluged into b of the core card and a of the accel
Re: sandra report
can any one see an issue in my sandra report? I should also note that my system worked well with a Process card. Unfortinitly I sold the process card to fund my accel purchase.
WHat I really don't want to happen is to buy another accel and get the same error. Thanks |
sandra report | vin7 | Windows | 3 | 03-26-2014 03:47 PM |
Sandra report | mickeyrouse | Getting Started | 3 | 01-13-2014 05:57 PM |
Sandra Report | keithaska | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2010 12:43 PM |
Thanks! Sandra Report | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-08-2009 09:26 AM |
Sandra Report Help Please | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-09-2007 05:52 AM |
