Old 12-19-2017, 04:27 AM
manichouse manichouse is offline
Default 12.8.2, HEAT, and DC Offset Bug
I've stumbled on a suspected bug in 12.8.2 that was supposed to have been addressed in 12.8.1. When turning the HEAT knob to the right, it is creating a substantial amount of DC Offset. It gets much worse at higher sample rates. To recreate, simply create a new session at 96khz, add one audio track with the signal generator plug. Generate a tone (I used 1khz and then again with 10khz) and turn on heat, turning the knob to the right. On your master fader, use a plugin with an RTA (I used Equality and also Insight). Look at the results. It gets worse as you increase the HEAT processing. On extreme settings with the tone at -10db, I was able to show DC offset that was as high as around -10dbfs! Anyone else able to recreate this? I'm on Windows 10... curious if Mac users are seeing this as well.
Martin Trum
Old 08-19-2018, 12:46 PM
Jeezer Jeezer is offline
Default Re: 12.8.2, HEAT, and DC Offset Bug
How far back does this bug go (I saw it was 'finally' fixed in 2018.X).
Did it appear in a certain version or has it been there since HEAT was a thing?
Windows 10 | i7 8700k Coffee Lake 6c/12t @ 5GHZ all cores | 3333mhz 32GB CL14 GSkill RJ Ram | 970 Evo SSD | PT12 HD @ 88.2k | ICON D-Command | Prism Titan Converters
Vid offset in PT 11 different then PT 10 emf1138 Post - Surround - Video 6 04-05-2014 11:47 PM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
DC offset - how to tell if you have it? musicman691 Pro Tools 11 3 01-09-2014 03:38 AM
bar offset ? frenchman Pro Tools TDM Systems (Mac) 4 07-10-2007 03:25 AM
dc offset anyway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-20-2001 05:31 PM
