Old 09-02-2008, 06:48 AM
John Edwards UK John Edwards UK is offline
Default Using shift function
Having a small problem.
I've mapped out a song with tempo changes and markers for verses, chorus's etc but the band have relised that one of the sections is too short.
Is there a way to insert bars into a session which shifts all tempo changes, markers and audio at the same time, or do I have to re-map the song?
Using the shift option only moves the audio.
Cheers
John
Old 09-02-2008, 08:20 AM
Stig Eliassen's Avatar
Default Re: Using shift function
I believe you can do this under the Event menu, then Insert Time. Can't be more detailed now - I'm not at the studio to try it out for you.
Old 09-02-2008, 08:41 AM
Cheers buddy
I'll give it a go and let you know.
John
Old 09-02-2008, 03:04 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Yeah, insert time is what you want. It will shift everything over including tempo, meter, key changes and markers.
Old 09-03-2008, 07:26 PM
elicious elicious is offline
all good answers, but i think our o.p. has audio already in the session and wants to move it all...
in that case copy the audio that the band wants lengthened, then shift- clic within the markers ruler (make sure it is showing), and then shift-clic again in the tempo ruler and so forth to cover all your bases.
copy that.
place the cursor where you want the section to be longer, then shift-clic again in each ruler (marker, tempo, meter, etc. one at a time.
then hit paste, good to go
e
ihatetyping
Old 09-03-2008, 08:23 PM
Scott Goldberg Scott Goldberg is offline
In the old folks home again Stig????
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
shift/alt/3 ???? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-28-2010 10:02 PM
Need to use shift key mingustoo Pro Tools M-Powered (Win) 0 09-03-2008 10:21 PM
Explanation for FORMANT shift in Time Shift Plug In, please! Darney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-13-2007 11:00 AM
I can't shift to Mac Pro... yuya Pro Tools TDM Systems (Mac) 0 11-27-2006 01:05 PM
Request for function buttons on DIGI 002 to function stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2003 06:57 AM
