Old 08-17-2008, 06:59 AM
dendee dendee is offline
Default trim tool on 7.4.2 ?
how to edit all the volume automation moves globally, like adding 2db to the whole track. this is now apparently possible on 7.4.2. anyone know how?
thnx
macbook pro 2.33
leopard & 7.4.2
toyota echo
www.myspace.com/dennydemarchi
Old 08-18-2008, 11:55 AM
Scott Church Scott Church is offline
Default
Sure, enable the all group, switch the tracks to Volume and use the Trimmer tool to increase the volume automation by 2db. Make sure to disable the all group when you are done
Cheers,
Scott
Scott Church
Old 08-18-2008, 03:46 PM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Default
You can change all the volume automation on a single track with the trim tool by simply clicking above or below the automation line and then dragging up or down. Make sure you don't have any of the automation line highlighted, or only the volume of the highlighted section will be changed.
Old 08-18-2008, 09:40 PM
Default
thanks.... the manual says trim mode was in HD only...nice to see it on LE !!
TCE Trim Tool Ginridge macOS 2 09-28-2012 08:15 AM
Problems with Grabber Tool & Trim Tool S133 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2008 10:19 PM
TC/E Trim Tool Mike62858 Pro Tools M-Powered (Win) 0 08-12-2007 05:38 AM
Trim Tool Bug poly915 Pro Tools TDM Systems (Mac) 12 08-08-2007 04:07 PM
trim tool TravisDRS Pro Tools TDM Systems (Mac) 2 12-16-1999 02:08 PM
