Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-24-2008, 05:08 PM
hankreas hankreas is offline
Default Macbook w/ Mbox Mini 2 Issue
Thanks ahead of time for those willing to help.
I have a MacBook with my Mbox 2 Mini hooked up and running ProTools. The problem I'm having is that when I plug my Gibson electric guitar (passive pickups) directly into the Mbox, the input comes in very high. What I'm trying to say is, no matter how low I have the corresponding input knob turned down, when I give the guitar a good strumming, it comes into ProTools "too hot." It hits the reds and altogether does not sound clear. Do I need a mixer in between the guitar and the Mbox or is there something with ProTools that I need to tweek?
I'm fairly tech savvy so straight forward answers will help.
Thanks again,
Hank
Old 07-24-2008, 09:45 PM
JChance JChance is offline
Default
Hi-
You'll probably want to post this in the "Pro Tools LE" Section, since these threads are for M-Powered users.
But to answer your question, doesn't the mBox mini have an input pad?
If so, plug your guitar into an input and engage the pad. This will reduce your incoming signal level, which is very useful for guitar, bass, etc. with passive pickups.
Then adjust your input knob to get the signal level you want.
Good luck-
Trying to use Mbox Mini (III Gen) with PT 10.3.2 on my MacBook Pro jjtarnow macOS 7 06-28-2013 04:29 AM
Help! Mbox 2 mini/ PT 8.0 issue with new MacBook Pro Godsace05 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-16-2011 03:11 PM
MacBook and MBox 2 mini fikafer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-20-2008 09:36 AM
MBox Mini + 7.4 on MacBook TCLguy1 Pro Tools TDM Systems (Mac) 0 02-28-2008 06:48 PM
new macbook and mbox 2 mini obcbeatle General Discussion 0 11-18-2007 01:15 PM
