Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 02-29-2008, 11:29 PM
aylutar aylutar is offline
Default Vienna Instruments
I just recently purchased the Vienna Instruments Special edition package. I'm running Pro Tools M-Powered 7.3.1cs6 on a MacBook Pro with 2GB of RAM. I can't get Pro Tools to recognize the VI plug-ins that let me instantiate new instruments. The best I've been able to do is use IAC to route the MIDI from Pro Tools into a standalone instance of Vienna Ensemble -- but this still leaves the issue of taking the output from VE back into the DAW. I've tried rebooting, removing all other plug-ins except the VI ones, and still I can't access them. Can anyone help me with this?
Thanks,
Andrew
Old 03-01-2008, 10:10 AM
Default Re: Vienna Instruments
The folks on the VI forum helped me solve the issue. Just in case anyone else stumbles upon this thread, I'll post the solution:
You must make a *stereo* instrument track, not a mono one.
--Andrew
Old 08-04-2008, 02:50 AM
oodelardeet oodelardeet is offline
Default Need help setting up multiple tracks with Vienna Ensemble
Hi Andrew,
I just purchased VSL Special Editions bundle and am using Pro Tools 7.4.2 on My Mac Pro w. Leopard 10.5.4. My issue is that I do not know how to create separate instrument tracks in Pro Tools so they will correspond with the instruments I create in Vienna Ensemble. Do I create another Midi track in Pro Tools and assign the corresponding instrument in Vienna Ensemble? an AUX track? I don't really know what I'm doing even though the Vienna Ensemble's brief instructions tell me how to get started. I understand that one instance of Vienna Ensemble can support up to 16 instruments. Please help so I can run these programs together as efficiently and effectively as possible. Thank you for your time.
Regards,
Jonathan
Mac Pro 3Ghz Quad w/8gb, Digi 003R Factory, PT LE 8.0.3cs2 on OSX 10.6.2
MacBook Pro 13" 2.53Ghz w/4gb, Mbox 2 Mini, PT LE 8.0.3cs2 on OSX 10.6.3
Vienna Instruments Puzzle Steve@ZooWest Pro Tools TDM Systems (Mac) 0 03-16-2011 01:03 PM
Vienna Instruments and PT 8 Not Getting Along scartabello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-03-2010 03:21 PM
ILIO Vienna Instruments, work OK w/EXpansion? pianosound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-29-2009 08:31 AM
Vienna Instruments TimNielsen Virtual Instruments 4 06-12-2009 06:11 PM
Vienna Instruments and Protools 8 Not Working Tom Polce Pro Tools TDM Systems (Mac) 13 03-25-2009 06:16 AM
