Old 04-05-2007, 11:24 PM
tomhartman tomhartman is offline
Default Anyone Had This Automation Problem?
I keep running into the problem of PT having a mind of it's own when it comes to writing level automation.
I'll be in touch, or latch mode for instance, and if a pass has already been made, I'll go to update something and grab the fader, either onscreen with the mouse or with a Command 8 fader and I pull the fader down, for instance, and PT ignores me and the fader onscreen shoots right back to the level already written. I finally end up having to go in the Edit window and draw it myself.
I'm in 7.3.1 cs2. 10.4.8
Anyone?
Thanks
Tom H
iMac 27
Old 04-06-2007, 07:54 AM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: Anyone Had This Automation Problem?
I've experienced unexpected results when in Latch or Touch/Latch mode and the mixing preferences are set to "Allow Latch Prime on Stop" - because you press play and it takes the level or pan position of where it's parked and writes that to the following played section.
http://duc.digidesign.com/showflat.p...part=1#1136165
hth, jim
noise | jimlongo
Automation problem seolwoo Pro Tools TDM Systems (Mac) 5 06-10-2008 09:09 PM
Automation Problem rastro2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-24-2007 09:55 PM
Automation problem jaketanner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2006 06:10 PM
Automation Problem March314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2005 10:55 AM
Automation problem Jeff Zubeck Pro Tools TDM Systems (Mac) 2 01-02-2002 04:43 PM
