Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-22-2008, 02:30 AM
abre abre is offline
Default Switched to Mac
I got my iMac and all is just fine. I have lost the use of most of my plugins (Vst) so I have to shop around for compatible ones. Which ones would be economical and would do a good job? I don't have plenty cash.
Old 07-22-2008, 12:25 PM
JrummerJ JrummerJ is offline
Default
You just need something like this, I believe:
http://www.fxpansion.com/index.php?page=15
J
Old 07-22-2008, 02:21 PM
dougied dougied is offline
Default
Or you can check out http://www.masseyplugins.com for some killer inexpensive plugs that have no expiration time on the demos.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 07-22-2008, 07:59 PM
Default
Yeah, the massey plugs are great! The wrapper would let you continue to use the plugs you have and have access to many more that are only available in VST format.
Old 07-22-2008, 11:54 PM
Default
I am seeing the Vst exe installation files only as text files. I have some Voxengo and Sonitus Vst plugins. I have the VST2RTAS Adapter installed already but cannot install the files.
Old 07-23-2008, 05:53 AM
Default
Unfortunately, it looks like these are PC only VSTs so you may be out of luck. Go to those company's sites and see if they offer a mac version. Then if it is VST format, the adapter will do its thing. From the FAQ at FXpansion:
Can I use PC plug-ins on a Mac, or vice versa? [top]
No. Mac VSTs work on a Mac, PC VSTs on a PC.
Old 07-23-2008, 09:40 AM
Default
Well that's it. I got to bite the bullet. All of my VSTs are for PC only. No Mac support. I would have to keep my PC around for a while then. I realized that you cannot make a change overnight.
Old 08-01-2008, 01:37 AM
Mattafact Mattafact is offline
Default
You could run XP via bootcamp to get you by if your iMac is intel based.
Breakthru Recording
www.myspace.com/breakthrurecording
Old 08-01-2008, 02:56 PM
Default
Oh yeaaaaah. As a matter of fact. Thats it. Where was my head. Thanks Matt.
Just switched from PC to Mac! eddiesound macOS 9 08-13-2011 08:19 PM
have you switched from Mac to a PC? Neale Eckstein Pro Tools TDM Systems (Win) 13 03-29-2009 09:41 PM
I SWITCHED!!!! Abomb97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-06-2007 11:42 AM
Anyone Here Switched From LE? cheekypaul Pro Tools M-Powered (Mac) 12 02-26-2006 02:47 PM
How Many Have Switched Over from DP4 to PT LE? PlanetPluto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-29-2003 08:00 PM
