Old 02-11-2004, 09:58 PM
Jim Roberts Jim Roberts is offline
Default Sluggish ProControl since OS Upgrade
G4 933
PT HD4
ProControl 32 faders
Everything has been running smoothly for months in OS 10.2.6 . The other day a client sent a session to the FTP site and my PT rig wouldn't recognize it. I was advised to upgrade to 10.2.8 and to repair permissions on my internal drive. I was hesitant, but checked Digi compatability documents and found it was OK to go to 10.2.8. So I did it.
Ever since then, the Procontrol seems to be running a bit sluggish. The counter hesitates a bit, a lot of meters hang, faders are a little bit slower to react than normal.
I've tested the PC by itself through it 's self tests and everything looks fine. I searched the DUC and couldn't find anything specific to my issue except for a problem we all had when we went from PT 5 to PT 6. This problem is not as severe as it was back then, but something isn't right.
It may be worth noting that I have also received some -9073 errors since upgrading as well. Haven't had errors like that in a long time from the SCSI days. All drives now are FW (7200RPM +).
Please help.
Thx,
Jim
Jim Roberts
www.musicandvideo.tv
Old 02-24-2004, 05:18 AM
Rob Macomber Rob Macomber is offline
Default Re: Sluggish ProControl since OS Upgrade
Jim,
call me..I'll come ckeck it out
R
Old 03-09-2004, 12:41 PM
Mano Mano is offline
You dind't write about which ProTools version you are running but.....
Have you tried ProTools 6.1cs3 ?
It fixes the ethernetbuggyness.
PT 7 sluggish .. ? Rob van Hees Pro Tools TDM Systems (Mac) 2 02-25-2006 03:29 PM
ProControl monitor upgrade / epot khoop ProControl, Control|24, Command|8 4 01-06-2005 08:32 PM
6.4 Sluggish LGiordano Pro Tools TDM Systems (Mac) 15 05-09-2004 12:28 AM
ProControl Monitor Section upgrade pmichalak ProControl, Control|24, Command|8 1 03-08-2004 06:31 PM
upgrade for ProControl? bootman ProControl, Control|24, Command|8 4 05-13-2000 06:13 PM
