FXpansion
please let me get this straight....
if i buy FXapnsion...i can use ANY vst plug-in?...no i-lok?...no dongle?...any mac compatible VST?... do they have to be NEW VST plug-ins to work with 10.x.x and 6.x.x????? please, someone help me...i mean this REALLY changes things if i can use my VST stuff inside of 10.x/6.x...right?... detroitkruk
The Used Stars |
Re: FXpansion
If the plugs in question use some form of copy protection, you will still need to use it. The FXpansion software is a wrapper for VST plugs to make them appear to be RTAS plugs (or rewire if you buy that version) to the host application, in this case, ProTools. It doesn't defeat copy protection.
If the plugs work on OSX, then you should be fine. I haven't tried to use older plugs and I won't be trying that since I don't own any. I can tell you that it works, and works pretty well. I got the FXpansion wrapper so I could use my UAD-1 cards in ProTools. I don't think much about FXpansion unless I am adding new plugs. It just works and that makes me very happy |
Re: FXpansion
I posted my situation about how Native Instruments Xpress keys (Pro-53 specifically) did not function properly with the fxpansion vst/rtas wrapper.I eventually found a workaround but I was basically told by NI and a DUCer that if a plug doesn't work properly ...that it's the wrapper's fault. Apparently it is the wrapper's (fxpansion) responsibilty to be compatible with the plug..and not the other way around.So in my experience, the answer to your question is "MAYBE".
www.jeffreyleecampbell.com Mac Pro 2.8 GHz Quad 16GB RAM Apogee Rosetta 200/ UA LA-610 Genelec 8030A/7050b McDSP, Waves, Sony, URS, Spectrasonics, BFD, Altiverb |
Re: FXpansion
The wrapper works well...I would say 95% of the time, I myself haven't ran into something that didn't work with it but I've heard somethings. Yes big or small you can make wrap any vst, but it may not work.
[TheLP] |
Re: FXpansion
Eric does this mean you have more than 1 card running smoothly ? If so Id like to converse with you about your setup as I and others have had problems wrapping 2 cards |
Re: FXpansion
I've got the wrapper and I love it but it doesn't work with every plug that I've tried. I purchased it in an attempt to try to integrate Soundsoap for noise reduction and it was a dismal failure. Once I had both of them loaded onto my computer it was easy to see why they wouldn't work together. At first I was disappointed until I realized how many free plugs I could download. Now I'm glad that I've got it despite having to shell out 500 clams for DINR LE (which suits my NR needs quite well). Just type "free vst osx" (if that's your OS) into a search engine. My favorite at the moment is the Blockfish compressor which is one of the fish fillets at digitalfishphones.com
All the best, +=G=+
Pro Tools Ultimate 2023.9 Dell Precision T7600 64 gigs of RAM Windows 10 Pro HD Native PCIe Lynx Aurora with LT-HD Apogee Mytek |
Re: FXpansion
Here's my tests of free OSX VSTs with the wrapper, also with links to the VSTs. themselves :
http://www.kvr-vst.com/forum/viewtopic.php?p=479837 For a few high-CPU plugs (Crystal, Carbon, DS-404 etc), I use Plogue Bidule instead to host them, seems to handle memory better. |
Re: FXpansion
While we are on this topic, has anyone tried the wrapper on the Oddity synth? Everytime I try the wrapper on it, the program just quits automatically on me.....
Re: FXpansion
there's a good forum for FXpansion and specifically the VST2RTAS wrapper on the KVR-VST website. Click on the Forums link about a third of the way down on the left hand side of the site, then scroll down to the FXpansion Users forum. You'll see a number of threads, including sticky threads specifically for the most recent version of the VST2RTAS adapter. It's updated frequently.
Hope this helps. |
FXpansion HELP!!! | kei122 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-30-2012 02:56 PM |
fxpansion BFD kit????? | redchair | Tips & Tricks | 4 | 12-31-2005 05:56 PM |
Help OSX 10.3.9 PT LE 6.4 and fxpansion BFD | lambro3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-19-2005 09:31 PM |
FXPANSION | proaudio3645 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-18-2004 11:33 PM |
FXPansion Help | fredsparky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-04-2004 10:25 PM |
