Old 01-05-2010, 11:42 PM
michael c michael c is offline
Default Problem with Digi Audio Midi Set Up in 8.03
We just upgraded to 8.03 using a Mac 8 core running OSX 10.5.8. When I open up Audio Midi Set Up to switch on my Digidesign interface in CoreAudio I just get a spinning ball. The midi side works but not the audio side. I am unable to play any other app through our 196.
It worked fine in 8.01.
Anyone else have this issue? Any help or suggestions?
Thank you.
Old 01-06-2010, 02:43 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Problem with Digi Audio Midi Set Up in 8.03
Thank you.
You could try remove the "Digidesign CoreAudio.plugin" file from the following location on your hard drive: Library/Audio/Plug-Ins/HAL
Then reinstall the coreaudio driver from the PT installer
or first....
You may also want to trash the ams prefs system drive/user/your name/library/prefs/ com.apple.audiomidisetup.plist
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.6 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2, Quad x2. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B Aphex 20Z. Hafler TRM active monitoring.
Old 01-06-2010, 10:49 AM
Thanks Chris! Trashing the ams pref did the trick.
Audio MIDI setup says DIGI 002 midi device is offline oliarnalds MIDI 17 10-23-2016 11:13 PM
Digi MIDI i/o Duplicated and greyed in Audio/Midi setup xxicjoy MIDI 69 08-02-2013 09:40 PM
Audio Midi Setup, Multichannel Audio Problem soundeditor76 Pro Tools 10 0 04-13-2012 05:49 PM
Digi TS: Problem w/current Digi Core Audio Manager Armando Pro Tools TDM Systems (Mac) 4 10-11-2006 11:08 AM
Digi 001 with Logic Audio - MIDI & Audio problems - please help! Paul Alexander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 37 02-25-2001 02:47 PM
