FCB1010 Pedals
I have a second hand fcb1010 with the 1.2 11Prom and noticed that the volume pedal didn't go all the way up on the animated page in the 11R in Protools. So I got out of PT and loaded up MIDI-OX and the volume pedal is sending CC7 from 7F (127) which is right for toe down, but 3F for heel down. Now this should be 0.
Is this something with the 11PROM or with the adjustment of the LED thingy in the FCB? Yes I have done the calibration in the 11R. Any Ideas?
================================== Win7x64 PT 9.0.5 DIGI003 Digimax FS ASUS P5E Q6600 6GB Eleven Rack + EXRP |
Re: FCB1010 Pedals
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Re: FCB1010 Pedals
Re: FCB1010 Pedals
At the end of this webpage they show the expression pedal mechanism:
http://www.el34world.com/Misc/Music/FCB_1.htm Getting the LED & Photodetector aligned is paramount. If that doesn't get you all of the range, then bend the LED & photodetector closer to one another (without hitting the plastic strip) - that should do the trick. Cheers, Dave http://www.eurekasound.com |
Re: FCB1010 Pedals
Thanks Dave. I did open it up and fiddle a bit (not with the hammer though).
I did align the emitter and sensor and that did help me get a few more lower numbers but not low enough. So I put a washer on top of the brass pegs (under the pc board) This raised the assembly up more towards the clear end of the strip. Now I can get down to 05 as the lowest CC. However when looking at the CC's in MIDI-OX it starts at 7F and continues for quite a lot of 7F's until it jumps to 3F. Then it seems to go down from there OK. Looking at the gradient strip, it doesn't even look like a linear gradient. Can someone run their FCB1010 directly to MIDI-OX and see if they get a linear gradient from 7F to 00.
Re: FCB1010 Pedals
Ok went back in and tried pushing the LED and sensor closer and on the volume pedal got a 00. On the wah pedal I lifted the pcb board up with washers like the volume and pushed the sensors closer and got 00 on that pedal too.
But I still get cc's on both pedals missing everything above 3F except 7F. Dave is this the 11PROM or does this happen with the original PROM?
Re: FCB1010 Pedals
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: FCB1010 Pedals
Ah great master of the nearly 10,000 posts, I could do that. Now this is where it gets embarassing when I first noticed this I did swap back, but then I was only looking to get the 00 as the lowest. In getting the 11PROM out a corner leg of the prom broke off (pre-weakened?) - by pushing the 11PROM back in it made enough contact to work OK but I am not game to try it again. I'll wait for 1.4
Re: FCB1010 Pedals
I have 1.3 in a FCB1010 and the pedals are smooth here. EPROMS are tricky. You need a good pair of jewelers or miniature needle nose pliers to straighten the pins with out breaking them. They are (too) fragile by design. I started to bend mine putting it in and had to stop and carefully straighten them all out. And I've done enough electronics work that I'm pretty comfortable with doing these things. The location of the PROM in the FCB is shaded by the lip of the unit. Get some light in there so you can see enough to ensure that the legs are lined up. Its worth spending a minute making sure that the legs on each side are all lined up in the same plane and that the angle of the legs is the same as the socket.
Re: FCB1010 Pedals
When you run expression pedal calibration on startup (Keep switches 1 and 5 pressed while powering up the unit) you'll get to see the actual values that the 11PROM is reading from the expression pedal circuit. Hopefully you see lows < 0x10 & highs > 0x70. (The values are in hexadecimal, so 0x0 to 0x7F would be 0-127). The 11PROM uses an algorithm to compensate for the pedals not spanning the entire range. But if the low > 0x40, or the high < 0x40 - the algorithm would act as you're saying. In general, you'll want the expression pedals to natively cover as much of the range as possible. Behringer, UnO, and our algorithms scale over the remaining range, but that inherently ends up skipping numbers, which you can hear if the jumps become too large... Cheers, Dave http://www.eurekasound.com |
FCB1010, which PROM? | ElectricEric | Eleven Rack | 10 | 09-17-2012 09:58 PM |
Two Exp Pedals? | Jermak | Eleven Rack | 0 | 10-24-2011 05:19 PM |
FCB1010: How do you get all 10 pedals to stompbox mode? | Jd0g33 | Eleven Rack | 7 | 06-09-2011 02:50 PM |
WAH WAH pedals? | Dezmond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-05-2004 10:31 PM |
RAT Pedals | Emo King | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-01-2002 12:59 AM |
