Minimoog V CPU problem PT9
I've been having issues with running Arturia's Minimoog V in Pro Tools 9 for a while. It used to be fine with an older configuration but now I'm having this problem : Whenever I load a few tracks with this plugin, the CPU usage gets to around 100% and nothing works. This is DEFINITELY not due to the fact I'm using too many plugins as I can use way more demanding plugins without any problem besides the fact that it uses a load of resources.
It's not due to anything that is widely known (such as recording on an external drive, wi-fi, background programs running etc.) I've tried everything. This is a much more complicated problem. Is there any known incompatiblity? I've tried rolling back to older versions of PT 9 (which worked fine before) and the same problem occurs. It might be due to driver updates but I'd like to know what other people think. I'm gonna do every test possible but it's gonna be REALLY time consuming so I'd appreciate it if anyone knew something about this! The next thing I'm going to try is running it with a fresh install without any updated driver nor SP1 installed, but this is crazy! Here's my Sandra Report SiSoftware Sandra Computer Model : Asus N61Jq Processor Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz Speed : 1.73GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Asus N61Jq BIOS : AMI N61Jq.206 02/04/2010 Bus(es) : PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR3 SO-DIMM Chipset Model : ASUS Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Intel Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.13GHz (4.26GHz) Total Memory : 4GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Mobility Radeon HD 5730 (400 SM5.0 650MHz, 1GB DDR3 2x800MHz, PCIe 2.00 x16) Graphics Processor STREAM Processor : ATI Mobility Radeon HD 5730 (400SP 5C 650MHz, 1GB 2x800MHz) Compute Shader Processor : ATI Mobility Radeon HD 5730 (400SP 650MHz, 1014.7MB 2x800MHz) Storage Devices Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (D:) MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890AS (SATA150, DVD+-RW, CD-RW, 1MB Cache) : 4GB (E:) Logical Storage Devices OS (C:) : 116GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) DATA (D:) : 335GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) EWQLSO XP Gold 1 (E:) : 4GB (CDFS) @ MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890AS (SATA150, DVD+-RW, CD-RW, 1MB Cache) Peripherals LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller Audio Device : ASUS P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : ASUS Redwood HDMI Audio [Radeon HD 5600 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 3 : ASUS uPD720200 USB 3.0 Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 95% Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Re: Minimoog V CPU problem PT9
Perhaps running Minimoog V as a VSTi in a ReWire Client will work as an interim.
Aaron Mulqueen - 001 HD Native |
Did the older configuration included the i7 720? Some plugs simply run better using 4 or less processors in PT.
Yeah I've tried all of that. The conclusion is pretty [bleep][bleep][bleep][bleep]ed up! The only problem was dust in the vent area of the laptop. It's crazy... everything is running fine now! I still find it weird that it's the only plugin that caused such problems... but oh well everything is working (almost, it's still Pro Tools, a time bomb)!
Classic.
MiniMoog Instrument | DJSTACKS | Tips & Tricks | 6 | 05-28-2006 03:22 AM |
MiniMoog and reg Moog problems... | Kryst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-28-2006 07:36 PM |
Arturia Minimoog... opinions? | wedgewedge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-09-2006 08:56 AM |
The Minimoog V is out | Cliffy_Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-29-2004 09:52 AM |
minimoog sound charts | bickele | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-01-2001 11:20 AM |
