Re: video issues 2018 HD
ok, it happens in 2018.3 too
my issues been happening since PT12.... so I assume .3 is the same
yes.. .3 is the same.
I used to work on PT 10 end it worked perfectly but now it's became impossible to work on video... I'm a sound designer and I produce audio for video. I cannot work without PT HD... Have you found a solution? |
Well.
Since I "hacked" PT 2018.4 video is much much better. I copied the videoengine from PT 12.8.2 into PT 2018.4. I have done this on two systems and all is good on both systems. No garanty that other problems arise, but I have done this several times with no problems. working with dnx hd and blackmagic Just right click on PT icon and open the program folder. Inside you have to open an other folder where you find the video engine Cant explain it better as I am here at home now. You can give it a try. Just make a finder copy of Protools if you make a mistake. Have fun Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
oh good! A bit tricky but may be the right way!
I've solved this problem more easily: the problem was that I've been working with a video with more than 4000x2000 of resolution and it was really too big. If I work with video with 1280x720 or little higher as 1980 I should work well |
#16
I always transcode any incoming video to Apple ProRes Proxy at no larger than 1980x1080. Less load on the machine = happier PT.
#17
Same encode format (H.264) but lower size (1980x1080) and PT works fine. |
#18
All this makes it harder for your machine to focus on running protools. Some motherboards have dedicated H264/5 decoder chips to ease the load, but most high end machines don't ironically. |
#19
really? didn't know it at all... I simply thought that it was a normal compressed video file and so it has to work on PT
#20
PT has never been happy with h264, and because of the nature of the compression, pausing on a still frame is not that accurate so trying to spot fx etc is very difficult. Transcode to Prores or DNxHD 36 and save yourself the heartache.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Pro Tools 2018.1 low latency monitoring issues | stakeoutstudios | Pro Tools 2018 | 61 | 04-15-2020 07:15 AM |
PT 2018:1 - video engine not working (for some) | noiseboyuk | Pro Tools 2018 | 13 | 04-05-2018 08:21 PM |
Issues running PT 12.x and 2018 on Late 2012 i7 iMac 27" 3.4Ghz 32GB Ram | foxes | Pro Tools 2018 | 26 | 02-18-2018 11:44 AM |
Pro Tools 2018.1 - Video Engine failing to load (Windows 10) | Lana Banana | Pro Tools 2018 | 2 | 02-08-2018 08:26 AM |
Sluggish Zoom in/out + scrub issues 2018.1 (MacOS 10.13.3) | Hrmonik | Pro Tools 2018 | 0 | 01-28-2018 10:35 AM |
