Old 02-08-2019, 06:14 PM
banjo71 banjo71 is offline
Default Can you use plugins to track through?
I have no idea if this question is even a valid one. I know very little about using plugins to track through. Can you do this with let’s say the Scheps 73 eq plug-in? I have PT 12.6.1 and a PreSonus StudioLive AR12 a/d converter.
Pro Tools 12.6.1 for Windows 10
ASUS Core i7 3770
HP Intel Core i5 Notebook
Focusrite Scarlett 2i2 Interface
Glyph 1TB GPT50 external drive
eSATA card
Equation F.20 condenser mic
AKG Perception 150 Mic
SM81 condenser mic
Old 02-08-2019, 08:17 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Can you use plugins to track through?
yes. create one aux input(stereo or mono whatever input source is) and one audio track. The aux track gets set as the input for your source and outputs to your audio track, the plugin goes on the aux also, et voila, you have printed through the plug in. However in order to have the least amount of latency means running lower buffer settings which in turn can cause issues if your system isn't sufficient. Which is why many just track while listening to what the track will sound like with the plugin on the audio track itself and commit after tracking if satisfied(dependent, again, on system resources
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 02-08-2019, 08:26 PM
Yes you can, but there are a few things to be aware of:
#1-some plugins have latency. A few samples(IK Amplitube has 7, for example) and those will likely be fine. But some have hundreds or even thousands of samples of latency(like Ozone), so those would make tracking a timing nightmare(so make them inactive if you need to track with them in a session***)
#2-some plugins use very little system power to operate(like EQ III and BF76) and you can use many(depending on how powerful your computer is). Others, like Ozone, Melodyne and many reverb plugins, chew up a lot of system power and you might suffer stops and errors at low buffer settings(which you want for tracking)
#3-since you're new to this stuff, a plugin that is bypassed uses the same amount of power as not bypassed. Making a plugin INACTIVE will free up all the power it was using when active(***)
My template session has around 36 tracks and is loaded with most of my mixing plugins. But(the great big BUT), and plugins with lots of latency or high power needs are inactive when I open for tracking. Once I finish tracking, I then make those plugins active and my mix is already in decent shape Set your MIX window(under the VIEW menu) to show Delay Compensation so you can see latency numbers. This will help you learn which plugins are okay for tracking
Old 02-09-2019, 07:53 AM
The Weed's Avatar
The Weed The Weed is offline
And if you record the plug-in or plug-ins' effects, then it's in the audio and, if you want to tweak the effects or don't like them, you'll have to re-record. As mentioned above, track with the plug-ins active, but not being recorded, i.e. the effects in the monitoring only, then it's easy to tweak because the actual audio recorded is "dry". Another alternative is to record the effects using the Aux to Audio track method and also record a "dry" track. For me, it's easier to just record dry, monitoring through plug-ins, then tweak as necessary or even add more and/or different plug-ins.
Note: Monitoring through plug-ins depends on what latency you're comfortable with, how low of a buffer your computer can handle reliably and how much latency the plug-ins you want to monitor through cause.
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 02-15-2019, 04:45 AM
chrisdee's Avatar
chrisdee chrisdee is offline
+1.
There are sometimes in the past I have regretted overcompressing or commiting an effect wich cannot be undone.
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 02-15-2019, 05:23 AM
amagras amagras is offline
Originally Posted by chrisdee View Post
+1.
+2
amagrasmusic.com
Getting plugins on Fast Track Duo? tgold Pro Tools 10 1 02-03-2017 06:22 AM
Keeping track of plugins dg27 Pro Tools 11 1 08-03-2016 05:09 AM
Plugins on a mixdown track paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-27-2008 10:31 PM
Intrument Track and Plugins? fasttraxx MIDI 11 12-26-2007 03:44 PM
Writing Plugins to the Track eon sol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-18-2002 11:57 AM
