What can be re-Wired
hello... I was wondering what programs were capable fo being used with re-wire. Can you use soemthign liek Cubase with it or Audacity? or is it just Reason..
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
Re: What can be re-Wired
i use sony acid pro 5, reason 3, fruitys 5, melodyne, magix studio 11,
and as far as i know if it has rewire funtions you can rewire it. hope this helps
Gear> C8, 002, Trigger Finger, Kontrol 49, Apc 40 SW > Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02 Plugs > All Registered plug in's & Vinyl out the wazoo. Mp3 sucks |
Cubase and Audacity are not Rewire "Clients".
(Cubase is a Rewire "Host"... like Pro Tools.) To use with Pro Tools, you need products that are Rewire "Clients". There is a brief list of RW Clients here: http://en.wikipedia.org/wiki/ReWire |
Thanks, which one out of the lsit uses the least amount of PC resources.. becasue all i woudl be using it for is to get past 32 tracks using the rewire on AUX's trick... so basically the program only needs to be able to play the wave files and nothing else
I don't have experience with this so I'll leave it for others. Have a look at this bit on spkguitar's help page though. How to get more than 32 audio tracks... His example uses Ableton Live. |
Reason is very CPU efficient.
You can Rewire Reaper. But there were some pretty bad bugs the last time I tried a couple months ago. They may be resolved now though since Reaper gets updated every few days.
002R outputs wired pin 3 hot ?? | john1192 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-28-2007 09:44 AM |
Uninstalling when Re-wired? + Warning | rabbitears | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-08-2005 05:10 PM |
Another test from the DOC - X73 wired backwards | Carl Fuehrer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-21-2005 10:33 PM |
I'm wired | spicyitaliano | Pro Tools TDM Systems (Mac) | 2 | 01-23-2003 04:41 PM |
wired news story | cuttooth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-27-2002 11:02 AM |
